05-06-2003, 02:23 PM | #1 |
2wd cab conversion for 4wd chasis
Ok, I am looking for options for mounting a 2wd cab on a 4wd frame.
Do you just cut a hole in the floor, and use a generic boot? Do you cut just enough for the shifter, and then put the 4wd tunnel plate on it? Do you cut most of it out and then mount the plate? Just looking for ideas... |
05-06-2003, 02:29 PM | #2 |
cut the entire trans tunnel out and put a 4wd trans tunnel in.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
