Old 03-31-2012, 05:27 PM   #1
Bethewaz
Crossover pipe ID?
Anyone know what this might go to?
I got it with a bunch of 67-70 parts. I know some of these are like hens teeth to a restorer to use as a template. Once I figure out what it is, I will post in WIW section.
Thanks in advance
Bethewaz is offline   Reply With Quote
Old 04-01-2012, 05:01 PM   #2
Bethewaz
Re: Crossover pipe ID?
No ideas?
Old 04-01-2012, 06:49 PM   #3
rsavage
rsavage's Avatar
The sections that bolt to the exhaust manifolds look like they are slanted as opposed to straight down drops. If it is a crossover pipe from a 67-72 chevy truck then it would most likely be for a small block two wheel drive as the 4 wheel drive exhaust manifolds are straight down. Can you hold it up under an engine in a truck to see?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
