03-31-2012, 08:51 PM | #1 |
What wiring harness is best?
I'm changing out my engine wiring harness(long story). Im using a Painless now but am not happy with it. Its an 02 6.0 that will be now DBW instead of cable. What harness are you running and how happy are you with it? How clean does it look on your engine?
03-31-2012, 08:57 PM | #2 |
Re: What wiring harness is best?
Nothing like modifying a stock one yourself.
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
04-01-2012, 02:38 AM | #3 |
meowMEOWmeowMEOW
i got mine from fuelinjectionconnection and they did me no wrong. Good service, came with its own fusebox and was made to order for my setup.
04-01-2012, 10:51 AM | #4 |
A guy with a truck
X2. The information is free on the web. It really is pretty easy once you dig in...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-01-2012, 08:05 PM | #5 |
I just did one for a buddy for a little cash. Pulled all the non needed wiring, labeled everything for the ignition, fuel pump, fans, powers, grounds, ignition, etc. Did not hang any relays as he is not sure where he will put them.
Also since his PCM is a 99-02 I reflashed it to get rid of vats, removed rear o2's, all smog related items, and prepped it for the big cam and fuel injectors. Posted via Mobile Device
04-02-2012, 12:06 AM | #6 |
I have a harness from SSP. He sells alot on ebay. It took a while to get it done but the finished product looks great!
Posted via Mobile Device |
04-02-2012, 12:19 AM | #7 |
Collector of Projects
here are three that I know of....
howellefi.com nelsonperformance.com hotrodlane.cc |
