Vintage Air Installation...
I am installing a Vintage Air kit in my '69 and running into a problem. I shaved my fire wall and decided to use a bulk head fitting for the freon lines and heater hoses. I am having a problem making up the lines for inside the cab from the evaporator/heater core to the bulk head fitting. I mounted the bulk head fitting approximately in the same location the lines suppiled with the kit would have passed through the fire wall. I am using Aeroquip fittings, the tightest bend fitting they offer is 135* and the Vintage Air hard lines supplied with the kit have 180* bends. Has anyone installed Vintage Air with a bulk head fitting instead of using the supplied lines for the evaporator? How did you solve the line connection issue? Any suggestions will be appreciated.
Re: Vintage Air Installation...
No one? I could really use a little input.
http://67-72chevytrucks.com/vboard/s...330869&page=19
He ran his lines hidden and I think he had to use a bulkhead fitting setup but I could be mistaken I think somewhere around pages 15-20 is the AC install if I remember correctly.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
