Old 04-01-2012, 07:12 AM   #1
jessewebb
jessewebb's Avatar
WTB or WTT: Compete Steering Linkage 71/72
Hi Guy's, I'm needing the tie rods and the center bar for a 71 or 72 C/10. If you have the pitman arm I'll take it to. I have the idler arm if its the same as a 69. I have all new tie rod ends and the center bar for a 69 but I have 71-72 spindles. Anyboby have this set up or anyone parting out a 71-72 LMK if your interested in trading or selling. Thanks Pete. Would also be interested in a good leak free PS gearbox. Mine is dripping alil and I'm not up for rebuilding it.
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 04-01-2012, 08:26 AM   #2
Todd68Chevy
Todd68Chevy's Avatar
Re: WTB or WTT: Compete Steering Linkage 71/72
I have a 72 that should have the center drag link. The tie rod ends are there but I would not gaurantee them to be good. As far as what I have been told the pitman and idler arms are the same but I should be able to look them up and be sure. The difference I am being told is that the tie rod end holes are larger on the 71-72. I was also told that they make a tie rod adjuster sleeve that actually lets you use your 69 parts and use these sleeves and a 71-72 outer tie rod end to make it all work.
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 04-01-2012, 08:37 AM   #3
jessewebb
jessewebb's Avatar
Thats the way mine is set up right now. I have the 69 tie rods and the 71-72 spindles. I was just going to swap the whole thing out, if I could find one at a reasonable price. I'm going to put drop spindles on. I may need to just keep what I have. I think I can go either way on the drop spindles. I've seen them for 69's and 72's. I tink I'll just order the 69-70 spindles, I have all new tie rods, and idler arm already. Probably be the cheapest way for me. Thanks
Pete
04 325i lady's ride
Old 04-01-2012, 08:37 AM   #4
Todd68Chevy
I just looked up 69 C10 w/ PS and a 72 C10 w/ PS thru Napa and it shows the same part number for the pitman arm and the idler arm. Manual steering shows a different pitman arm than power steering box.
Old 04-01-2012, 08:40 AM   #5
Todd68Chevy
There might be someone on here that has the new stuff they are not going to use so you might give it a little time. If you are interested in my used center link just let me know and I will get it checked and some pictures. Good Luck.
Old 04-01-2012, 09:14 AM   #6
jessewebb
jessewebb's Avatar
Thanks Todd, I just ordered the drops for a 70 model, I'm just gonna use what I have it's all new anyway. Probably have to change the ball joints. Maybe not. I'll find out when the drops get here. Thanks for your help
Pete
04 325i lady's ride
