Old 04-01-2012, 09:28 AM   #1
summerj
PULLING TRAILER WITH C NOTCHED FRAME... to CUT or NOT CUT???
Anyone pulling a trailer with a C Notchhed Frame? I have a short Bed 65 Fleet Side. Bags in Rear Drop Spindles up Front. I would like to have more suspension in the back and go a little lower.
Installing a reece frame hitch.
I will be pulling a small double axle catering trailer with electric brakes. I don't want to cut the frame if I am compromising frame strength.
Those of you that have C Notched:
Do you notice any difference in the strength of your frame behind the AXLE?
summerj is offline   Reply With Quote
Old 04-01-2012, 10:39 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: PULLING TRAILER WITH C NOTCHED FRAME... to CUT or NOT CUT???
You might find this FAQ of interest-
Frame Notch Based On Strength
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-02-2012, 01:25 AM   #3
andrewmp6
Whats the weight of the trailer tho?Just remember its a old truck they can't pull the weight of a modern 1/2 ton can.
andrewmp6 is offline   Reply With Quote
Old 04-02-2012, 09:19 AM   #4
summerj
Trailer Tung weight is about 200lbs. Its a double axle trailer so all of the weight is on the trailer itself. + trailer is only 10' long. 2000lbs total trailer weight. I have the 2500lb air bags in rear. KYB shocks. 350 ci with 700R4 trans . 373 gears. I am going to air up the bags when the trailer is behind it. W/O trailer behind truck I air bags down to about 10lbs- But I only have about 2.5 " of suspension travel when truck sits level.
Those engineering drawings are very informative with the c notch data. -
Based on what i saw with these drawing spects- the only sure way to c noth w/o comprimising strenth is to do the boxed Full/exagerated C notch. Everything else weakens the frame to different degrees. The constant movement of the trailer/hiting bumps in road would probably wreak havoc on a standard C notch.
I think I will just leave the frame stock for now.
