Old 04-01-2012, 09:36 AM   #1
GMC1965
Need help with rust repairs on 65 c10
Below are some photos, Its definitely got some rust to her. My plan was to fix all rust, prime with an epoxy(that way I can still drive it around a little, not to work just to town (5-10KM). Then once ready to paint, id spray 2k feather and sand smooth. Then paint. Does this sound ok? Back on the rust, looking for any tips or help on these certain areas. For panals, I have front fender bottoms,bottem door skins, full rockers, I will order 4 cab supports, I think I need something In the back below the gas tank tho, its gone. Also in the box, the lip is gone all the way around, can I make them? Any treads? What size welder would I need for panels, my friend has a big stick one for frame work. And for painting is a 2HP running 6 peak 20 gallon big enough for priming. Paint il get a 70gallonish. My pass door is bent out any ideas.
GMC1965 is offline   Reply With Quote
Old 04-01-2012, 09:39 AM   #2
GMC1965
Re: Need help with rust repairs on 65 c10
More
Old 04-01-2012, 09:41 AM   #3
GMC1965
even more
Old 04-01-2012, 12:06 PM   #4
MARTYZ
MARTYZ's Avatar
Good day fellow Canadian, Best advise I have is make a list and start scrounging for donor parts or replacement pieces that are available. Get your hands on a small mig with gas, 110 volt will do the job, sheet of metal and see what you can do.Tackle one problem at a time. Trial and error is the best training you can find. If you mess up cut off and do it again. Any questions you have along the way I am sure you will get answered here on this Forum. What have you got to lose! Time and a bit of metal. Go for It
MARTYZ is offline   Reply With Quote
