4" Tuff Country Ez-Ride 56" Rear Springs
SOLD!
These are from my retired 3/4t Suburban. They didn't see a lot of use because the vehicle was only run occasionally since I work out of my other truck for a living. The bushing sleeves are not rusted and the cushions are still like new. I used the front springs on my Jimmy and bought new 52" springs for the rear rather than drop the tank,modify the bumper mounts,and hitch to move the spring mounts back. In a pickup that originally has 52" springs,this is an easy mod to give better flex/ride and will be a bolt-on deal on trucks that came with 56". SOLD! Here's a link to Suspension Connection for details: http://www.suspensionconnection.com/...-suburban.html
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-26-2012 at 09:59 PM. |
Re: 4" Tuff Country Ez-Ride 56" Rear Springs
$600 springs for $300
Want better pictures? Sorry,I forgot to vacuum the rug
Here's better pictures after I cleaned them up (never did vacuum that rug)
4" lift EZ-Rides. 56" long. Will really improve the ride on a 4wd that came with 52" or bolt-on if it came with 56". It's easy to move the spring hangers back.
Just tryin' to squeeze this one little thread in here amongst the many others. Sure is hard to keep a thread from falling into oblivion these days with the amount of members constantly keeping several threads up on the 1st page.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 05-30-2012 at 09:02 AM. |
I see there's some matching front springs listed now,so I thought I'd bring their rear counterparts back for a quick visit to the top again
![]() Join Date: May 2006
Tim, do you take lay-away? How far do you have to move the rear mounts?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 06-06-2012 at 10:50 AM. |
I believe 4" because these are 56" and the shorter ones are 52". If you are interested,I will work with you. Any chance you'd make it to Carlisle Trucks? If you did buy them you could get them there to avoid shipping.
#10 | |
Talked to the people at your link, they said that i should move spring mounts out 2" on both ends. Gets rid of my blocks, and keeps the axle centered Thanks
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Hmm...you should only have to move the rear mount back 4" and the front stays in the stock location. The center bolt is not centered on the 56" spring; the back half is 4" longer on a 56 than a 52 but they both share the same dimensions on the front half.
Posted via Mobile Device |
#12 | |
Makes it easier for me to only move one spring mount, per side Tim, did your suburban have a factory shackle, dont know if it matters,but im putting these springs on my jimmy with a factory shackle
#13 |
First of all,I always understood it as blue 70k5 describes...just move the rear back,pin is same dimension from front on 52" or 56". The frame rail runs straight all the way back,so no affect on ride height. If the front was moved it would lower the mounting point (raise the vehicle),just like when putting longer springs in front. When installing the even longer 88-up rear leafs (64"?),then you need to move the front mount forward as well as rear backwards.
Yes,I used the factory shackles. How does having them paid by Carlisle Trucks sound? That's about two months away...first weekend in August. Maybe you could bring last payment and carry them home? Works for me if it works for you. But,I'll work with whatever you want to agree on.
#14 | |||
Charlie Daniels w/ a Tq Wrench
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#15 |
Thanks guys for all the info., great thing about this board, the input...
Tim, thank you for the liberal time constraint, but was hoping to have them paid off by the end of June(pension check). PMO or paypal, ill accept fees on my end I realize you live out in the country, but, would it be a great expense to get to a greyhound terminal Anyone know where to get u bolts, was going to contact DIY4X for the greaseable leaf spring bolts Now i have to deal with RIVETS
#16 |
Greyhound is no problem,but may have another solution. PM sent
#17 | |
As far as the rivets, if you have access to a cutting torch that is the fastest way to knock the head of the rivet off then knock the rivet through. If not a cut off wheel and making little X marks in each rivet, then using a chisel to break off the little bits of the head is pretty easy. Don't waste your time drilling or grinding away on them.
#18 | |
#19 | |
So, when total due comes in, i will have about 220., coming your way, balance by end of month or sooner... Thank you for the deal, good seller
#20 |
That sounds great. I met up with Jimer64 and he's hoping to get back down for the bed and axles before too long and is willing to take them back to Coatesville. My feeling is it should time out well for you. We'll keep in touch on it.
#21 |
OK, ive got 200, collected from parts. Do you want a PMO.....
#22 |
Yes,that would be best...thanks
SOLD!
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-26-2012 at 09:58 PM. |
