C/10 junkie
WIW and what's it from fan shroud
I picked this up for my truck but it looks bigger/wider than the fan shroud that was on my 72 2wd 350 auto. Is this a 4x4 shroud or for a big block or what and what would it be worth? Thank you.
![]() ![]() ![]() ![]() Posted via Mobile Device
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
C/10 junkie
Re: WIW and what's it from fan shroud
Also I should add that I'm going to be putting a 327 in my 68 swb in the 6 cyl position would this shroud be the ideal set up because it's so deep? It definately looks like it will fit my radiator.
![]() Join Date: Apr 2007
Looks like a 4x4 to me. The big chip will hurt the value. I would say $50-65. Sharpie
Can you find a part# on it?
1971 Chevy shortbox 4x4 made in Canada |
C/10 junkie
Unfortunately I don't see any part numbers on it. Will this work on a 2wd?
Member #1049
I agree with Sharpie.. its looks to be for a 4X4. I can not say for sure if it would work with a v8 in the 6cyl position.
I can only tell you what it would be with a part#. I'm still learning about these trucks so I can't go by looks but I have a parts manual and interchange book. I think you could make it work it would just depend on the fan you choose and the spacer you use. I dont see why it wouldnt bolt to your rad I think all the rads are the same just different thickness. Hope that helps
C/10 junkie
Thats what I thought to. May want to sell if it dont line up with my fan and spacer.
C/10 junkie
Ok it's for sale here http://67-72chevytrucks.com/vboard/s...d.php?t=517412
| Bookmarks |
