Old 04-01-2012, 01:21 PM   #1
frog210
Can you take a look at these pics and tell me whats missing or wrong?
Im in the need of some assistance guys
can yall take a look at my pictures of my carb and engine
and tell me whats wrong or missing?
idk but I feel like theres something wrong or missing
like the spring to the carb
and the choke(I think) is missing the connector
can yall tell me how to fix or tell me where to get it
or how to do it...
(can yall take a look at all the pics and tell me whats wrong or missing)
thanks in advanced
frog210 is offline   Reply With Quote
Old 04-01-2012, 01:55 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Can you take a look at these pics and tell me whats missing or wrong?
Your missing a Holley to go with them valve covers lol
But it looks like your choke isn't wired
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-01-2012, 02:25 PM   #3
frog210
Thats how I got it lol
How would i wire it?
Whats the choke for? whats the purpose?
Could i just wire it or does it go with a certain connector?
Old 04-01-2012, 03:31 PM   #4
joe231
joe231's Avatar
You just need a hot wire that is switched on when the key is on.
The positive voltage heats up the coil under that cover and opens the choke.
You are going to need to adjust the choke after you get it wired.
CHEVY ONLY
Old 04-01-2012, 04:15 PM   #5
beamn7
Also looks like the choke pull off is missing on the pass. side of the carb (2 holes on the side of the carb by the p/s side mounting bolt) and the open port on the front is the vent for the float bowl. Should have a hose that goes to the canister.
beamn7 is offline   Reply With Quote
Old 04-01-2012, 04:21 PM   #6
frog210
Choke pull off?
Float bowl?
What do these do?
Where can i get them?
Old 04-01-2012, 04:36 PM   #7
frog210
Should the choke flap be open like that even do its off?
i would think it would be close so no contaminants can get in
Old 04-01-2012, 06:09 PM   #8
russgt
russgt's Avatar
Should be open for normal driving and closed for cold starting. Not sure if you guys in texas even need a choke? lol
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 04-01-2012, 06:17 PM   #9
frog210
You made my day lol
Old 04-01-2012, 06:35 PM   #10
beamn7
Float bowl is integral part of the carburetor. Dont worry about that. You just need to run a hose from that open port to the vapor canister that should be mounted behind the drivers side headlight under the hood. The choke pull off should be easy to purchase from a local auto parts store. What it does is slightly opens the choke when you first start the engine so as to allow air into the carb. The choke coil heats up (once your run a keyed hot wire to it) and slowly opens the choke. When the behicle is warmed up, the choke will be open all the way....
Old 04-01-2012, 07:12 PM   #11
jhngardner367
jhngardner367's Avatar
Fellas,Is this an April Fool's Day Joke???
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 04-01-2012, 07:24 PM   #12
frog210
No I really need help
Old 04-01-2012, 08:00 PM   #13
ozark
I wasn't going to say but, turn that distubutor counter clockwise a tooth or two so it sits right.
ozark is offline   Reply With Quote
Old 04-01-2012, 08:16 PM   #14
mud.man.rj
mud.man.rj's Avatar
Are you sure this isn't an April fools joke, if not then find a smart friend to help you and put him to work wiring the choke with a keyed pos.power sorce and check choke adjustment after that and move that fire hazard of a fuel line over the hot exhaust, rubber lines burn and then the truck.
mud.man.rj is offline   Reply With Quote
Old 04-01-2012, 08:48 PM   #15
donut
donut's Avatar
Throttle return spring runs parallel to the throttle cable (under).
Connects on the bottom of the throttle arm, runs back to the mount the throttle cable is on.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 04-01-2012, 09:44 PM   #16
frog210
okay my truck turns on, but when i put it in
reverse, drive it turns off
i dont think my choke is closing like yall stated
if i hold on the gas it runs
sometimes it turns on but dies 5-20 seconds later
idk its making me mad
another thing it sounds like air is leaking from somewhere
Old 04-03-2012, 05:34 AM   #17
lurch115
lurch115's Avatar
does that work with the universal style throttle brackets like what he has on there? i've found that alot of times the springs are too long for that.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 04-01-2012, 10:12 PM   #18
86c20
86c20's Avatar
then the idea is to low there is a srceew on the drive side by the cable likage that will bring it up some give it half a turn and you should hear the motor speed up some
86c20 is offline   Reply With Quote
Old 04-02-2012, 08:06 AM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
do you smog it?
check a few things
where does the vac advance for the distributer go
if your air filter breather housing has hoses parts on it,prob easier to remove it all
use your finger carefully cover any holes it the carb
start with the big ones,they sell caps to plug them but short bits of hose will work temp with bolts in the hose bits
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-02-2012, 08:27 AM   #20
frog210
Smog it?
I have class at 8, but I will try this when I get out at 9
I'll take some better pictures when I get home of my carb
Old 04-02-2012, 09:27 AM   #21
motornut
78K & 79C Jimmys
motornut's Avatar
some states make you do an etest
and they check for these parts to be attached before they will test it
testing for polluters.....
John
Old 04-02-2012, 11:00 AM   #22
dead civic
dead civic's Avatar
I'm sorry to thread jack. But I'm new to all of this. And i keep paying a 20 here and there to shops that say they will adjust my carb properly.
but i just read that it is supposed to be opened during driving.
here is my issue. i always have to adjust it, because if it opens all the way the truck stall bad after a completes stop. Sometimes even turning off and not getting anywhere, So i have to have it mildly open instead of wide open... is that normal or can you fellas drive your vehicles with a wide open choke?
any input is greatly appreciated.
00 EBP civic SI [not stock for sure]
03' Jet black CTS {slammed on ksports}
79 C10 [real project]
POW MIA. .SMOKE TIRES NOT DRUGS.
dead civic is offline   Reply With Quote
Old 04-03-2012, 03:56 AM   #23
lurch115
lurch115's Avatar
ummmm.... -scratching my head- you,ve got some serious issues there. it should look something like this.... lol i'll see if i can't find you a better picture and post it on here for you.
Old 04-03-2012, 04:54 AM   #24
lurch115
lurch115's Avatar
lol let me try again.
Old 04-03-2012, 05:17 AM   #25
lurch115
lurch115's Avatar
hopefully this helps. my microsoft paint skills suck.
top right image shows the vacuum canister behind the driverside headlight. the arrow is pointing to the port that you need to hook the "floatbowl vent" too.
second image down on the left shows the correct style choke housing(circled to the left side of image). notice there isn't a vacuum port on it. the capped off port circled to the right of the image is the "floatbowl vent" you are missing the metal nipple there.
the second image down on the right is showing that you do have a choke pull off (circled part)that should be hooked to a small vacuum port at the bottom back side of the carb.(not the threaded hole thats for the brake booster). the vacuum line in red needs to be eliminated. cap off the port on the passenger side and hook your distributor vacuum advance to the port on the driverside.
the bottom image shows you where your distributor vacuum advance is(circled to the left of image). the vacuum line in red i am guessing goes to the heater box. if so unhook it from the front of the carb. and cap that port off. that line should hook to the intake vacuum port shown in the top left image(lower circled port just behind the carb.)
