Old 04-01-2012, 04:00 PM   #1
Stefan.
Stefan.'s Avatar
Power Steering Fluid
Hi,
I will retrofit a power steering.
What sort of oil use the Power Steering?
ATF Oil or Power Steering Fluid?
Stefan
Stefan. is offline   Reply With Quote
Old 04-01-2012, 06:51 PM   #2
jocko
jocko's Avatar
Re: Power Steering Fluid
Should use regular old power steering fluid from the auto parts store.
Old 04-02-2012, 01:07 AM   #3
Captainfab
60-66 Nut
The correct fluid to use is power steering fluid. However, I have used ATF many times with success. If you can find power steering fluid use it. If you can not find that, then ATF will work.
Old 04-02-2012, 04:14 AM   #4
Stefan.
Stefan.'s Avatar
Thank you!
I found Power Steering Fluid, I use this.
