Add more oil in diff after lift?
I added more lift to my Blazer. With the diff rotated more toward the trans do I need to add more oil to ensure proper lubrication?
Will add pics later, went from 4" to 6-7" with 35" mud grapplers.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys 1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers 2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers, ![]() 2009 Acura MDX |
Grease Monkey
Re: Add more oil in diff after lift?
No as long as it was filled properly before then you will be fine. At any angle the ring and pinion will pick up plenty of sticky gear oil.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Perfect, I had just replaced the diff oil so all should be good! Thanks.
| Bookmarks |
