Old 04-01-2012, 08:43 PM   #1
MLB57
fixed my repop door today
This is what I did to fix the door hitting at the curve and the front corner, worked well for both areas
MLB57 is offline   Reply With Quote
Old 04-01-2012, 08:55 PM   #2
chiefcfd
chiefcfd's Avatar
Re: fixed my repop door today
Nice job, Way to make it work. Everything has to be tweeked on these trucks.
chiefcfd is offline   Reply With Quote
Old 04-01-2012, 09:13 PM   #3
black_sheep454
The last ones I did I just took the top hoop of off the original doors and put on the repops, worked great.
1968 chevy lwb, getting ready to join forces with the 70 gmc
1970 gmc swb, getting ready to be a 68 chevy swb
1971 gmc lwb 2500 2wd Sierra Grande
1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins
black_sheep454 is offline   Reply With Quote
Old 04-01-2012, 09:21 PM   #4
pat 70/71
pat 70/71's Avatar
I did the same thing on a pair of doors that came off a dump truck! I had a gap of 1/2" at the top when I mounted them. I drilled out all the spot welds(as you did) put the top loop where I wanted it and welded her home! Glad you stayed with it! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 04-01-2012, 09:56 PM   #5
29od1
Did you have older repop doors? What brand were they?
29od1 is offline   Reply With Quote
Old 04-01-2012, 10:04 PM   #6
GruntMoanCough
GruntMoanCough's Avatar
Yeah, sometimes they don't weld things in the right place. Good job.
I replaced doors on frod once, the skins weren't even welded to the shell.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 04-01-2012, 10:08 PM   #7
MLB57
They were lmc doors. Can't blame the door the original door hit at the same places.
