Old 04-01-2012, 10:39 PM   #1
C-10 simplex
Plastic boring?
i need to bore this tube out just a little---maybe 1-3mm.
Any suggestions?
If you are wondering, this is the corner part of those cubical partitions.
C-10 simplex is offline   Reply With Quote
Old 04-01-2012, 10:53 PM   #2
woodwright
Enjoying left field
woodwright's Avatar
Re: Plastic boring?
maybe one of the round flap wheels that fits in a drill
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 04-01-2012, 11:00 PM   #3
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: Plastic boring?
X2, or if you have a friend with machinery, a lathe or boring machine would work.
Why do you need it bigger?
low'n slow is offline   Reply With Quote
Old 04-02-2012, 12:01 AM   #4
C-10 simplex
Re: Plastic boring?
Nevermind----i used a dremel. Although further suggestions would be greatly appreciated.
As far as why i need it bigger. Well, i'll tell you later.......
Old 04-16-2012, 02:31 PM   #5
pat 70/71
pat 70/71's Avatar
Re: Plastic boring?
Not sure on how long the tube is, heres my.02 Set the tube in a fixture(through a table top on its end) get a flush trim type router bit and change the bearing to get the offset you need to get the size hole your looking for. Machine in as far as you can from both ends. Make a dowel that fits the new profile with a little room so you can add sand paper to it and an arbor& put it in a drill and go to town on it! or, just find a piece of tubing with the correct inside diameter. all this talk about plastic is getting boring! cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 04-16-2012, 10:27 PM   #6
chevyrestoguy
chevyrestoguy's Avatar
Re: Plastic boring?
Use a wheel cylinder hone on a 3/8" hand drill
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
