04-02-2012, 01:15 AM | #1 |
Computer mount
Where is everyone mounting their computers? I have been trying to figure out the best place to put the computer.
04-02-2012, 01:24 PM | #2 |
Re: Computer mount
I have a driver side aux battery tray in my K5 and I hide the pcm and tac module underneath it. Other than the wiring loom, they are completely out of site. However, on my c10 I will probably just mount it on the driver side inner fender for simplicity and easy access.
I redid my own wiring harness and did not extend the wires for them to reach into the cab...
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
04-02-2012, 04:54 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Computer mount
I am relocating mine from the DS fender to the heater box on my firewall, along with the cruise module and some insulation. I am hoping I can get the wiring so it cannot be seen.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-02-2012, 05:51 PM | #4 |
Re: Computer mount
you guys have any pictures?
04-02-2012, 05:56 PM | #5 |
Home Built '87
Re: Computer mount
I put mine above the heater box in the cab...needed some trimming.
Pics are on the last page of my '87 build.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
04-02-2012, 06:07 PM | #6 |
Re: Computer mount
I pulled mine so I could get the paint done ( on the heater box). but if you look for them, some guys have them although they actually are heaters
here is one just like it but I dont have the blower motor on mine( bottom)
04-02-2012, 07:42 PM | #7 |
Re: Computer mount
how are the pcm's mounted in the stock vehicles?.....not where, but what holds them in place?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
04-02-2012, 09:27 PM | #8 |
A guy with a truck
Re: Computer mount
There's a bracket mounted to the battery tray on most trucks. Couple of bolts to pull it out- can probably modify it to work in your application.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
04-02-2012, 10:00 PM | #9 |
meowMEOWmeowMEOW
Re: Computer mount
drivers side kinda behind the headlight area, there is venting there so it gets airflow, and its rubber isolated on the bottom and again on the top with the rubber latch.
04-03-2012, 09:55 AM | #10 |
Re: Computer mount
Who did your harness BR3W?
04-03-2012, 12:24 PM | #11 |
Re: Computer mount
Mine is mounted on the inside of the firewall behind the gauge panel. You can see the bottom of it if you look below the headlight switch. It was totally hidden from sight once the a/c vents, etc. were installed.
04-03-2012, 12:25 PM | #12 |
meowMEOWmeowMEOW
Re: Computer mount
fuelinjenctionconnection did it. Told him what I was looking for, and what parts I was running and he had it to me in about 2 weeks. Came with the new fuse box (sans the goofy cover i put over it) and the wire and connector quality was very high.
04-03-2012, 01:58 PM | #13 |
Re: Computer mount
Cool, thinking about doing an aftermarket harness to get my PCM where I want it.
04-03-2012, 10:09 PM | #14 |
Always a work in progress
Re: Computer mount
I have totally re-vamped my whole harness to put it in the cab. I disconnected all the wires from the computer connectors and drilled a hole behind the intake to hide all the wires. My altenator, TB, and MAF route under the intake and my coil packs and injectors are on the inside of the fuel rail. Don't mind all the pink wires, I am still working on that.
My computer will be mounted where the old ESC computer was mounted.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
04-03-2012, 11:56 PM | #15 |
Re: Computer mount
I used the factory fuse box(cut and modified) and drilled holes in the bottom to mount the cut and modified plastic pcm mount to it. You can see the top of the factory cover on the left of the fusebox in this pic.
~Jon Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=516056 |
04-03-2012, 11:59 PM | #16 |
A guy with a truck
Re: Computer mount
Nice! This is how I did my last one. Are you having to lengthen/shorten any wires? Are you running a MAF?
04-04-2012, 09:37 AM | #17 |
Re: Computer mount
chevydrivor73, My 82 I mounted mine behind the glove box in the cab. Had to trim a couple of fins down to get it to sit like I wanted it to. Added some heavy duty velcro to it and stuck it up to the top of the fire wall above the heater box.I went thru the factory hole in the firewall. I used a factory harness and had the lengthen a few wires to move it there. I used a rubber grommet from the truck I parted out to finish out the hole. Worked out great and really kept under the hood cleaned up. Heres a couple of pictures.
04-04-2012, 09:43 AM | #18 |
A guy with a truck
Re: Computer mount
Nice work, homemade!
04-04-2012, 11:32 AM | #19 |
Re: Computer mount
mounting mine on fender drivers side. I am using the ecu mount from a 98 & up S10. $10 bux from salvage yard. Looks good.
04-04-2012, 02:39 PM | #20 | |
meowMEOWmeowMEOW
Re: Computer mount
