Old 04-02-2012, 11:23 AM   #1
loudnlifted88
loudnlifted88's Avatar
looking for pictures of leveled or lifted a little but 1999-06 gmcs
my buddy has a 2000 gmc mostly stock besides 285s exhaust and intake... ive been tryin to talk him into a leveling kit so i would like some pictures to show him what his truck could look like... his bars are already cranked to about the max it doesnt look lifted.
IM ONLY 18 AND LOVIN IT
IF MUD AINT FLYIN YOU AINT TRYIN!
1badgmc- Just think. Someone worked hard to make it look that bad.
1988 chevy stepside 305 five speed Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383945
1994 GMC ext. cab short box 350 auto Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=438873
1996 GMC 2500 ECSB 454 4l80e: build thread http://www.gmt400.com/forum/showthre...gmc-2500-build
1998 GMC K-1500 ECSB 305 auto partd truck
1999 GMC K2500 suburban 350 4x4 Dads project
1981 Corvette 350 auto Also Dads project
1989 Corvette 350 auto ^^
1998 GMC K1500 ecsb 305 auto Brothers project
loudnlifted88 is offline   Reply With Quote
Old 04-02-2012, 07:35 PM   #2
Boog
laying low
Boog's Avatar
Re: looking for pictures of leveled or lifted a little but 1999-06 gmcs
His truck looks pretty much level as is. My 2000 GMC with 285's sits just about like that.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-02-2012, 07:43 PM   #3
Boog
laying low
Boog's Avatar
Your friend's torsion bars may be weakened a good bit but I have a lot more available lift left in mine by cranking them up if I wanted to. I want to go the other way with mine, drop it 2 or 3 inches. I don't offroad so lift isn't important to me.
Boog
primer is finer
Old 04-02-2012, 09:59 PM   #4
loudnlifted88
i think they are weakened because he has a plow will ford keys do the trick it had about a 1.5 inch rake
Old 04-03-2012, 06:45 PM   #5
BLK2K2SILVY
BLK2K2SILVY's Avatar
He might not get much more even with ford keys. When the tbars are shot you can only get so much crank out of them.
Tell him to pick up a 1.5" body lift from zone offroad to get a little more clearance.
BLK2K2SILVY is offline   Reply With Quote
Old 04-04-2012, 11:08 AM   #6
loudnlifted88
body lifts are illegal in maine. so should he get some new bars and ford keys from a junkyard? he doesnt want to go up much just enough to make it so the tires dont rub when he backs up turning
Old 04-15-2012, 07:31 AM   #7
DetroitDan
DetroitDan's Avatar
body lifts are illegal in Maine?? WTF, why? Does Maine DOT think they know better than the engineers who designed the body lift in the first place? Like anything else, a properly designed and installed aftermarket accessory is only as good as the installer. If that is a fact, somebody ought to challenge it. I think they may be confused by the homemade hockey puck bodylifts that people used to use, stacking pucks with low-grade bolts and splitting the pucks. Even so, it's not likely to cause an accident, it's just going to let your cab settle onto the frame crooked.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 04-15-2012, 08:04 AM   #8
DetroitDan
DetroitDan's Avatar
holy cow, I just spent a half hour reading Maine lift laws, sounds like they have backed off a little and dont totally prohibit the bodylifts on abs vehicles, but the computer or vssb has to be calibrated so the abs works properly. But then it goes on to say tires should only be allowed to be upsized two sizes. Elsewhere it says 'within reason'. Well, in who's reason? Because I happen to think 40 inch tires are pretty reasonable.
OK, so I've decided not to move to Maine.
Old 04-15-2012, 08:05 AM   #9
DetroitDan
DetroitDan's Avatar
NH has a little lift law quirk: the inspection manual the inspection stations use says that the allowable 30 inch maximum height is to be measured at the frame, while the motor vehicle code the police use says to measure to the bottom of the bumper. That's a good 2-3 inch difference on my truck
