Old 04-02-2012, 11:38 AM   #1
KellerMAC
KellerMAC's Avatar
Picture needed of loaction of sending units on 72 C10 350
Can someone be so kind as to post a photo of the location of the oil sending unit on a 1972 C10 350 CID engine. I believe it is back of the intake manifold on the block but I don't see it. If you have a picture of the location of the temp sending unit, that would be greatly appreciated.
Thanks in advance,
KellerMAC
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 04-02-2012, 11:44 AM   #2
hayhauler71
hayhauler71's Avatar
Re: Picture needed of loaction of sending units on 72 C10 350
coolant sensor drivers side cyl head between the 1 3 spark plug oil sender right behind distributor if it has a gauge you will see the copper line sorry no pics
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-02-2012, 01:00 PM   #3
mrein3
mrein3's Avatar
This is what an oil sender looks like if you have an oil light. If you have an oil pressure gauge, a copper line will be coming out of that hole and attached to the oil pressure gauge in your dash.
It is the part to the left of the distributor in this photo. This photo is of the back of a SBC engine I pulled.
Sorry I don't have a photo handy of the temp sender in the head.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
