Old 04-02-2012, 12:39 PM   #1
JCampbell
73-80 to 81-91 Front End Conversion
I've heard inconsistent smatterings of rather ambiguous info regarding the need to modify the front frame horns when dropping a 81-91 front clip onto a 73-80 truck.
I always thought said conversion was, for the most part, "bolt-on" (aside from notching the cowl for the hood hinges). What's the deal? Do the frame horns need modification, too? Anybody have pics? I'd rather do it now while I have a bare frame sitting in the garage, than fight with it later.
JCampbell is offline   Reply With Quote
Old 04-02-2012, 12:57 PM   #2
Dalaigh
Canadian Trucker
Dalaigh's Avatar
Re: 73-80 to 81-91 Front End Conversion
Heres are pics of the difference
1973-80
81-91
and where you need to cut, to make the 81-91 front end fit
Then the bushings are different as well, but I think the bushings for the year of the frame will work, with the 81+ front end.
2020 Silverado Trail Boss - 6.2/10spd
Dalaigh is offline   Reply With Quote
Old 04-02-2012, 01:01 PM   #3
wilkin250r
wilkin250r's Avatar
VERY INTERESTED!!! I've actually got one of these, but the conversion was done before I acquired it, so I don't really have any details of the conversion process. But I'm interested in knowing the details of the hood. The 73-80 hood comes all the way back to the windsheild, the later years have a panel about 8 inches wide between the hood and windshield.
So what I've got is a short hood and a 8-inch gap between my hood and windshield. So I've got one of two choices, either fabricate a custom hood that has the front portion of the one style, and the rear portion of another, or find a way to mount that panel, probably welding some tabs to mount it to.
What I CAN offer is pictures of my truck and what has already been done. But I they're crappy, all the welds look terrible, it's not lined up very well, I don't know if they'll be of much use.
EDIT: Sure enough, after seeing those pictures, my front frame horns are cut. However, mine weren't cut at an angle like the pictures, mine are cut square, hacked off with just enough room to utilize the bolt hole on the top there.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 04-02-2012, 02:55 PM   #4
Dalaigh
Canadian Trucker
Dalaigh's Avatar
What you need is to find a cowl from an 81+ truck, then once you set it in place you'll see where you need to drill holes. The cowls are set in to holes up by the window and screwed to the firewall at the bottom, just below the hood.
Like this
and you will need to indent the edge for the washer fluid squirter
You can see where the hole in the fender needs to be for the hood hinge.
For the most part it is a bolt on process, but there is some fab work. It's a lot easier the go from 81+ front end to 73-80 front end.
Old 04-02-2012, 02:58 PM   #5
Dalaigh
Canadian Trucker
Dalaigh's Avatar
You also need to swap over the 81+ wiper rotating assembly, the 73-80's are too short for the cowl panel, and if going the other way the 81+ rotating assembly is to tall for the 73-80 hoods.
Old 04-02-2012, 03:56 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
You might want to look at this before cutting your frame- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-02-2012, 07:13 PM   #7
JCampbell
Good to know. Thanks.
Old 04-02-2012, 08:32 PM   #8
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I did my conversion following this article: http://coloradok5.com/grilleswap.shtml
My old website was taken down. I had some really nice conversion pictures. I need to get them off my old computer and put up again.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
