Old 04-02-2012, 04:21 PM   #1
mm1077
mm1077's Avatar
brake pedal return?
Is there a return spring for the brake pedal on a 1978 c10 with non-power disk brakes? If so, is it hidden somewhere out of view? My pedal doesn't return when depressed (have to pull back up with my foot) which also makes the brake lights stay on too. I'm just starting out trying to troubleshoot this...
mm1077 is offline   Reply With Quote
Old 04-02-2012, 04:52 PM   #2
joe231
joe231's Avatar
Re: brake pedal return?
I had a problem like that.
Turns out the bolt that holds the booster rod to the pedal was backwards and rubbing on the pedal mount.
Another cause of this could be a bad booster. Does it hold vacuum after you kill the engine? Do you hear a sucking sound when you depress the brake pedal?
CHEVY ONLY
Old 04-02-2012, 05:45 PM   #3
mm1077
mm1077's Avatar
It doesn't have a brake booster, just the master cylinder bolted to the firewall... Its hard to tell if it makes a sound or not because right now there's only about an inch of travel in the pedal before the brakes engage. It looks like the seal on the inside of the cab where the pushrod goes in is leaking (or has leaked in the past) too due to the rust that's all over the pushrod and the pedal parts. Something might just be bound up, but if there was a spring that was missing that would be an easy fix
Old 04-02-2012, 05:50 PM   #4
joe231
joe231's Avatar
Oops
Sorry
I missed the non-power part...
In that case I'm guessing that the master is bad.
CHEVY ONLY
Old 04-02-2012, 07:11 PM   #5
Phillip Pennartz
The spring is in the master cylinder.
When you are bench bleeding a master cylinder and your pushing the piston on the back, that spring is what is pushing back.
If pushing the brake pedal to the floor and it doesn't come back up and the pedal is not binding then you probably need another master cylinder.
Phillip Pennartz is offline   Reply With Quote
