Old 04-02-2012, 05:21 PM   #1
osaltyone
osaltyone's Avatar
gas tank question
I am thinking of taking the plunge with a 5.3 been reading everyone's builds, but was wondering on my gas tank. I have one of the under bed aluminum tanks from Brothers. I am not sure if it is baffled. Do I have to have a baffled tank? Can I just get the Walbro fuel pump and Corvette filter? I had a 3rd bung added on my tank for the evap system on my current 305. I assume I will leave that hooked up, but not sure.
osaltyone is offline   Reply With Quote
Old 04-02-2012, 05:53 PM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: gas tank question
I think you can go with the tank you have if the fuel pump fits in it.
Bob went with older unbaffled tanks on his Glock build and he said not to drain the tanks below about 1/4 so there was always enough gas for the pumps.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 04-02-2012, 06:10 PM   #3
osaltyone
osaltyone's Avatar
I thought the Walbro was an external fuel pump. I did not realize I would need one inside the tank. I thought it would go inline from the lower port on the tank to the filter then no the the fuel rail. I will have to call around to see if I can find a in tank fuel pump for it.
Old 04-02-2012, 06:16 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The walbro would work fine, external pump is fine but internal pumps are quieter and last longer since they are cooled by the fuel.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-02-2012, 07:38 PM   #5
mooseknuckles
mooseknuckles's Avatar
you could always weld a sump in the botom of the aluminum tank....
mooseknuckles is offline   Reply With Quote
Old 04-02-2012, 07:39 PM   #6
mooseknuckles
external pumps are still cooled by fuel....
Old 04-02-2012, 09:30 PM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Unbaffled tend to run dry, whether internal or external. Check out Tanks, Inc. for their drop in internal pump setup with a sump that allows you to run an internal pump with no baffling...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
