Old 04-02-2012, 09:01 PM   #1
tommym
350 lt1
this is my first time posting on here but I have a 68 chevy truck and was thinking about putting in a lt1 350 from a 1996 chevy caprice and i was wondering if anyone has done this and will it fit?
tommym is offline   Reply With Quote
Old 04-02-2012, 09:09 PM   #2
hugger6933
Re: 350 lt1
It has been done several times. Have you tried a search for it on here? I recall something about the rh motor mount being a different bolt pattern on that LT1 motor[ I think the bolt holes are upside down ] to clear the A/C compressor. I had a 95 ImpalaSS with that LT motor and loved it . In fact I have one sitting at the shop I've been waiting for the right project to use it on. My SS got like 25 MPG out on the hiway I don't think that there is much difference in the weight of the two, but the truck is not very areodynamic.Where you planning on using the EFI setup or going carb and dist?
hugger6933 is offline   Reply With Quote
Old 04-02-2012, 09:16 PM   #3
6772owner
Gearhead
6772owner's Avatar
Re: 350 lt1
I used a 96' Camaro LT1 and the factory (well urethane for me) engine mounts bolted right to the block, the block has the same holes as the Gen 1 engines (as well as the holes for the Camaro mounts)
A/C compressor will not work in the factory Camaro position, I believe the Corvette brackets or aftermarket are the ticket because these position the compressor the top of the drivers side. I am not sure where the Impala brackets position the compressor though. Check out my build thread for pics.
Oh and with a 700R4, 3.73's and a 255/55/18 tire I get roughly 14-15 mpg depending on the driving habits and highway speed(s).
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 04-02-2012, 09:18 PM   #4
70cst
70cst's Avatar
Re: 350 lt1
Hey tommym ...
Let me the first to to a wonderful truck forum and from Ohio. Glad to have you part of the family.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-02-2012, 10:20 PM   #5
huey-71
huey-71's Avatar
Re: 350 lt1
Welcome to the forum! I have no technical input as far as transplanting it, but I do have a fairly healthy LT1 in my 92 Corvette. Gets good fuel economy, and enough power to get in a lot of trouble. More of a higher RPM motor, but when you turn it up they run pretty well...
huey-71 is offline   Reply With Quote
