Old 04-02-2012, 09:46 PM   #1
blownz
Active Member
Turbo 350 205 T/C Leak
My 72 K5 is leaking trans fluid into the T case. I have had it apart twice and still leaking. The first time, I had the seals backwards. My second attempt, I took apart a virgin 205 and adapter. The original seals were in there and I took the seal to the parts house, they matched, I re-installed correctly. Thought I had it licked.... wrong! After checking on the Net, I found an old posting from us,
hdfslf wrote on 11/30/2008: Actually there are 3 seals. Been there done that. There are 2 seals on the outside diameter of the coupler (these are the likely leak path). Pay attention to the direction they are installed since they are backwards from what you would normally see. Third seal is a thick o-ring on the NP205 input shaft which seals with the inside diameter of the coupler.
Does anyone know what size o ring or have a part number for it? I am getting ready to take apart and would like to have the part on hand.
blownz is offline   Reply With Quote
Old 04-02-2012, 09:51 PM   #2
blownz
Active Member
Re: Turbo 350 205 T/C Leak
Old 04-02-2012, 09:56 PM   #3
blownz
Active Member
Here is a pic of my K5, also getting ready to take the top off for the summer.
Old 04-02-2012, 10:58 PM   #4
rsavage
rsavage's Avatar
Maybe you could post brand and part numbers of the seals and the o ring for reference?
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 04-03-2012, 06:54 AM   #5
blownz
Active Member
I will post the seal info later today.
Old 04-05-2012, 12:08 AM   #6
tdkosta
tdkosta's Avatar
Working on mine too. I can't seem to get the yoke nut off the front output.
tdkosta is offline   Reply With Quote
Old 04-05-2012, 03:38 PM   #7
Firebirdjones
Big impact.
Firebirdjones is offline   Reply With Quote
