Front grill removal??
How do you take off the front grill on a 63' I see a screw on the outside bottom edge but I dont see any other mounts yet it won't come out. The headlight rings are already off, do the headlights have to come out as well?
![]() Join Date: Jul 2009
Re: Front grill removal??
There's six 5/16th bolts (three per side) that go through the grille support from the back side. Two are lined up vertically toward the inside and the third is in the bottom outside corner behind the headlights. You don't need to remove the headlights, just disconnect the electrical at the harness plug.
