Old 04-03-2012, 02:05 AM   #1
rynophiliac
rynophiliac's Avatar
Where do the door bumpers go?
Where do the door bumpers go and how many of them are there on each door? My blazer only has 1 door bumper on each side right now right by where the door handle is in the door jamb. I see two more holes that look like they could be for more bumpers? One hole is on the bottom of the inner door (below the hinges) and the other hole is on the bottom near the corner of the door (on the latch side). Are these two holes for door bumpers also?
rynophiliac is offline   Reply With Quote
Old 04-03-2012, 09:25 AM   #2
29od1
Re: Where do the door bumpers go?
Two rubber bumpers per side. One at the top as you described and the other contacts the lower part of the door on the B pillar (where you have the lower hole on the latch side).
There are no bumpers on the A pillar that I'm aware of. That hole between the hinges could be for an interior light contact switch. I think that may have been an option on Blazers.
29od1 is offline   Reply With Quote
Old 04-03-2012, 07:21 PM   #3
rynophiliac
I want to make sure I understand you correctly. I made this picture and uploaded it as an attachment to help. Is this where the bumpers should go?
So there are no door bumpers on the side of the hinges?
Old 04-04-2012, 12:47 PM   #4
29od1
That picture is correct, and there are no bumpers on the hinge side.
