Do you need to change the driveshafts for a 6" lift?
I want to put a 6" lift on my truck, do you guys think i will have to change the front and rear driveshaft, and possibly brake lines? i have a 4" lift that came with a rear driveshaft, will that be enough? Thanks, dave
Re: Do you need to change the driveshafts for a 6" lift?
your driveshafts will be fine with a 6". most kits come with relocation brackets for your brake lines, but the extended brake lines are way better
^^who I am^^ what I say>
Should be just fine If your d-shaft has already been lengthened for the 4" lift. I installed a 6" rough country on my swb with the stock driveshafts, The rear is a little short but Ive had no problems out of it.
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
| Bookmarks |
