nv4500 conversion
I searched but I need specific info. I have a 1988 1 ton crewcab, sm465 four speed, hydraulic clutch, 350 TBI engine, 2 wheel drive. I want to switch to an nv4500 for the overdrive. What exactly do I need to do, which years trans do I hunt for. Thanks in advance, Trevman.
Re: nv4500 conversion
Anyone, anyone? Mr. Hand
Any years should be fine as long as it came out of a Chevy 2 wheel drive. Pay attention to the syncros on a used NV4500. You'll need to shorten your driveshaft.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
BAD BOW-Silverado XST
NV4500 conversion info: http://www.novak-adapt.com/knowledge/nv4500.htm
Advance adaptors: http://www.advanceadapters.com/categ...-packages/216/ |
Check out this thread: http://67-72chevytrucks.com/vboard/s....php?t=431033/
I know it's 4x4, but the meat & potatoes are there for a trans swap.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
