Old 04-03-2012, 05:03 PM   #1
ScottRussell
My 59 Apache project
My project, beginning to present... My Wife purchased for Christmas... It is on an 86 Monte Carlo Frame with chrome suspension and rear end, 350 Motor and 700R4 transmission... I took it completely apart, except Cab off the frame... The firewall has been smoothed, frame cleaned sanded and painted, motor and transmission re-installed.
ScottRussell is offline   Reply With Quote
Old 04-03-2012, 06:03 PM   #2
_Ogre
_Ogre's Avatar
Re: My 59 Apache project
see your other post for my comments on your tilt hood.
i like the look of your truck, something old skool that draws my attention.
i've always liked the side mount spare too.
i also noticed the gmc fleet option grill
since you have it down this far, change out your cab mount rubbers,
it will improve the way your fenders fit.
might as well shave that cowl seam while you have the front end off
shop air compressor timer
Old 05-21-2012, 09:50 AM   #3
ScottRussell
Finally had time to do some work on the truck... Finished smoothing the firewall... Replaced the pasenger side step and cab corner... went junk yarding and got a new steering coulmn and power seats from a 93 S-10 Blazer... Pictures to follow....
Old 05-21-2012, 10:38 AM   #4
ScottRussell
Replaced cab corner pictures...
Old 05-21-2012, 10:44 AM   #5
ScottRussell
Repaced Passenger step...
Old 05-21-2012, 10:46 AM   #6
ScottRussell
Firewall Smooth... part two...
Old 05-21-2012, 10:49 AM   #7
ScottRussell
New seats and steering column, seats are power leather.... both from a 93 Chevy S-10 Blazer, need help on wiring diagram for the column....
Old 05-21-2012, 04:07 PM   #8
Kim57
Kim57's Avatar
Looking good.
I'm having trouble finding seats that I like for mine.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 05-21-2012, 05:27 PM   #9
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Cool project! Keep the pics coming!
ChuckDriver is offline   Reply With Quote
Old 05-21-2012, 08:05 PM   #10
_Ogre
_Ogre's Avatar
s10 column looks a lot like the astro van column i used
weld up a mount for that column, that mount looks a little cheesy
it's the only thing to keep you straight and narrow going down the road
Old 05-21-2012, 08:42 PM   #11
_Ogre
_Ogre's Avatar
firewall looks real good
Old 05-22-2012, 08:47 AM   #12
ScottRussell
Talking Re: My 59 Apache project
Ogre,
Roger that on the mounts. That is just a mock up to get the connections for the linkages lined up, to get the steering box. There will be a solid mount at the dash and a solid flange where the column goes through the floor. I acutually will be removing more floor board to get a better angle on hte column.
Thanks for the quick response and for the wiring manual. I will keep the pictures coming as I move along the process.
Sincerely,
Scott
Old 05-22-2012, 09:34 AM   #13
waybad
waybad's Avatar
looks great
waybad is offline   Reply With Quote
Old 05-22-2012, 10:02 PM   #14
_Ogre
_Ogre's Avatar
you don't want to tilt the column too far back or you will run into header/exhaust interference problems
i went through the top of the existing column cut out and had no problems
but you can see how close it is to the block hugger headers
it's also a good line up with the mustII rack
you can't see it in the picture, but...
when i installed the dash cluster bezel i had to grind the lower point of the bezel off to clear the column
i installed my seats high to get a little more leg room for my 6'4'' frame
Old 05-22-2012, 10:08 PM   #15
_Ogre
_Ogre's Avatar
ahem, just a bit
notice i don't post these pics in my build
