Old 04-03-2012, 09:05 PM   #1
shultzee13
99 Suburban 2WD 1500 series - SQUEAKS
Not applying the brakes just turning corners or dips on the highway....it squeaks! For sure from the passenger side.
Any ideas what it could be? Can someone point out all the grease fitting locations? I gotta grease gun.
Also....could it be suspension parts (shocks/struts springs)
Thanks guys.
shultzee13 is offline   Reply With Quote
Old 04-04-2012, 07:31 PM   #2
bighaas79
Re: 99 Suburban 2WD 1500 series - SQUEAKS
I would guess ball joints.
bighaas79 is offline   Reply With Quote
Old 04-04-2012, 08:28 PM   #3
Boog
laying low
Boog's Avatar
Yes mostly likely the lower ball joints. The zerk fitting should be on the back side of the ball joint pointing to the rear of the truck. With grease and dirt buildup it can be difficult to find.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-08-2012, 12:12 AM   #4
bwood
bwood's Avatar
The front end should have 11 grease zerks:
1. Pass Upper Ball Joint
2. Pass Lower Ball Joint
3. Pass Outer Tie Rod
4. Pass Inner Tie Rod
5. Idler Arm to Center Link
6. Idler Arm Bracket (next to lower radiator hose)
7. Pitman Arm to Center Link
8. Driver Inner Tie Rod
9. Driver Outer Tie Rod
10. Driver Lower Ball Joint
11. Driver Upper Ball Joint
Also check the drive shaft U-Joints, if they have been replaced, they may have grease fittings.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 04-08-2012, 02:08 PM   #5
truckdude239
truckdude239's Avatar
most ly your lower ball joints are empty on greece and it it been squeaking for a while probley going to need to be replaced
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
