04-03-2012, 09:51 PM | #1 |
Hows my dizzy look?
Well im my list of things to check to get rid of my bogging down just off idle I wanted to see what everyone thinks about the contacts in my dizzy?
04-03-2012, 09:56 PM | #2 |
Robert Olson Transport
Re: Hows my dizzy look?
id clean that up real good and see if it helps but for the price of a rotor and cap id prolly just change it ... your pics are dark but it looks pretty dirty and burnt in there
04-03-2012, 10:26 PM | #3 |
I agree with old Rusty.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
04-03-2012, 10:42 PM | #4 |
How do you guys suggest cleaning it? Sandpaper on the contacts?
04-03-2012, 11:00 PM | #5 |
sand paper or sand cloth or a red sctoch bright pad
04-03-2012, 11:19 PM | #6 |
Replace it, its worth the money to have new
~Jon Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=516056 |
04-04-2012, 05:30 AM | #7 |
for no more than a new cap and rotor costs... if you have to ask, odds are you should replace it. not trying to be a smart allick, just my 2cents.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
04-04-2012, 08:18 AM | #8 |
Canadian Trucker
Just curious, I don't know what else you've done to figure out why your truck bogs off idle, but it sounds to me like you need your timing checked.
It still looks to me like you need to replace your cap and rotor, but if you haven't timed the engine, I'd be doing that first.
2020 Silverado Trail Boss - 6.2/10spd |
04-04-2012, 12:09 PM | #9 |
Just here to tinker
Stumbling can be lots of things. Replace your cap and rotor as stated above. While you're in there, make sure that your vacuum advance mechanism is free and not all gummed up. After that, check your timing. If you still get a stumble, try connecting your vacuum line from your distributor to a manifold source instead of a ported source. If all that fails, you may have a fuel issue.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
04-04-2012, 09:40 PM | #10 |
78K & 79C Jimmys
(replace)cap rotor,looks time,maybe plugs too?
not sure if done but replace fuel filter, remove and clean out line from pump to carb take the rotor off have a look under it @ the advance weights
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-05-2012, 10:21 AM | #11 |
Yeah, from the pics, looks like it's just time to replace.
If you just want to clean it up, sandpaper will get you by.
1st - '68 long bed 2nd - '81 SWB Now - '86 SWB, Edelbrock 1406/stock 350/700r4 |
04-05-2012, 11:40 AM | #12 |
The cap looks worn. Cheap to replace. What kind of carb do you have? Could be an issue there too.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
04-05-2012, 01:00 PM | #13 |
Accel sell complete distributors, Streetfire is the one I use. It was $25 more for that then rebuilding and upgrading the old one, so more the worth the price to get completly new unit with a high output coil. Typically the bog off the line is a carb issue.
My 2 cents...
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
04-05-2012, 01:24 PM | #14 |
Ive set my timing with a timing light at 0 degrees but might try advancing it a few degrees and see if that solves it, it has new plugs, new vacuum advance, wires are good, new fuel filter, pretty new edelbrock 1406. I figured id see how the dizzy looked inside and wanted to get a few second opinions. Ill pull the line from the pump to carb and check how clean it is as well.
Thanks for all the help guys, its much appreciated! |
