SM465 identification
Is there any positive way to identify how many splines are on the transmission input shaft without removing the transmission from the truck (SM465, 4 speed, granny low).
Re: SM465 identification
I've got an SM-465 sitting in my shop. I'll count the splines and post up tomorrow.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
I've only ever seen 10 teeth on the heavy trannies. That continues to the NVG4500 used through the late '90s.
1project2many... you are right! I was confused while reading the SM465 article on Novak Conversions web site. The output shaft came in three flavors... the input shaft only came in a 10 spline 1 1/8 diameter.... thanks!
