Old 04-03-2012, 10:25 PM   #1
m00n1957
rear main seal, 454, 85 4x4 ???
will the oil pan come off a big block in a 4x4 ?? will the motor jack up high enough to clear cross member ? my rear main seal is pouring, will it be just as easy to pull motor out ? cause i know the fan shroud is coming lose and distributor will probably have to come out.
m00n1957 is offline   Reply With Quote
Old 05-01-2012, 03:36 PM   #2
hartbraker
Re: rear main seal, 454, 85 4x4 ???
I just dropped my pan. You have pick the truck up by the frame so that the front axles drops to it's lowest point... but then again, I have 6 inches of lift so your situation may require you to pull the motor as my situation was a tight squeeze to get the pan off. Good luck, don't mean to discourage you... but I got my rear and front main done and they both still leak. And I bought the good gaskets and used rtv where suggested. I was so mad it wasn't even funny.
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
