05-06-2003, 11:36 PM | #1 |
Fuel Gauge Question
OK Here is goes,
How do i get the gauge to read empty when the tank is empty? its empty and it reads 1/4 tank gas. I cleaned the contact part of the float, cleaned the sensor contacts sofar. Any other ideas?
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
05-07-2003, 12:17 AM | #2 |
Ground the fuel sender wire and see if the gauge reads exactly Empty or there abouts. If its 1/4 off, the gauge is likely bad. Someone could have installed the wrong resistance bar (on the back of the gauge) but its doubtful.
If the gauge reads empty, you have a bad sending unit or something is restricting the float movement. |
