Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-04-2012, 12:57 PM   #1
Kim57
Kim57's Avatar
Header?
I've got an LS2 going in my project. It's rated at 400/400 from the factory.
I'm looking at 2 different sets of headers.
http://www.sandersonheaders.com/Sand...s-Engines.html
These have 1-5/8 tubes with a 3" collector.
http://www.sandersonheaders.com/Sand...eader-Set.html
These I can get with a 1-3/4 tube with a 3" collector.
Is there going to any difference on a street driven engine with the smaller primary tubes?
Thanks for any input.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-04-2012, 01:34 PM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Header?
I am not qualified to speak about the LS motors, but from a old school small block view,, and ESPECIALLY on the street driving at normal RPM's... a 1-3/4" header is more suited to 4000-7000rpm, 500+HP and USING all the ponies the motor can offer.
Torque is king on th estreet.. and long tube, small diameter primaries build better low ROM torque than large ones. A header is designed to carry exhaust away, BUT the scavaging effect of the port / header primary has a LOT to do with cylinder filling. If the exhaust over scavanges the cylinder (too small of a tube too much volocity) fresh fuel ends up burning in the exhaust. Too large of a tube and the volocity stalls,, and you get little to no scavaging effect and poor cylinder filling... spoiled intake mixture and poor efficiency, poor performance,,, poor idea. Size really does matter and too big hurts! (that sounds like a poorly chosen grouping of words doesn't it LOL)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-04-2012, 03:15 PM   #3
Kim57
Kim57's Avatar
Re: Header?
I can get the second set in 1-5/8 primaries also.
Kim
My build thread
Old 04-04-2012, 07:52 PM   #4
Super73
Super73's Avatar
Re: Header?
Yes this is a 6.2 liter motor but the Dino results are interesting..
http://www.performancetrucks.net/for...esults-496455/
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 04-04-2012, 08:23 PM   #5
Kim57
Kim57's Avatar
Re: Header?
From what I've seen on some other forums the LS engines need at least a 1-3/4 inch header so the 1-5/8 wouldn't be a good choice.
Kim
My build thread
Old 04-04-2012, 08:31 PM   #6
BigDan3131
BigDan3131's Avatar
Re: Header?
If I was reading that right the 1 7/8 were falling on their face after 5200 rpm and the other set was but not so severely.
Can you not get stepped headers for ls based motors?
BigDan3131 is offline   Reply With Quote
Old 04-04-2012, 11:18 PM   #7
Super73
Super73's Avatar
Re: Header?
You are not reading that right. The 1 7/8 made more power from the start of the pull and then they were the same afterwards.
Old 04-04-2012, 11:35 PM   #8
Kim57
Kim57's Avatar
Re: Header?
They make them but they are kinda pricey.
I'm looking at the Sandersons because I can get a good deal on them and if they don't fit they will take them back..
I'm probably being to anal about it because I wont be racing it but I don't want to choke it down either.
Kim
My build thread
Old 04-05-2012, 12:34 AM   #9
Super73
Super73's Avatar
Re: Header?
I am getting away from my stepped header, 1 3/4 to 1 7/8 for a straight up 1 7/8 version. But with that said, I made 521rwhp through a locked up 80E with those 1 3/4 stepped headers.
