Old 04-04-2012, 02:06 PM   #1
JCampbell
‘73-‘80 and ‘81-‘91 Dashboard Interchangeability
I’ve been operating under the assumption that the sheetmetal dashboards are the same from ‘73-‘91 and that the ‘73-‘80 and ‘81-‘91 dashpads and instrument clusters are interchangeable. Can anyone confirm this?
I’m updating the interior in my '77 to a ‘81-‘91and want to make sure it’s as simple as swapping dashpads and clusters and that I do not need to swap in an actual ’81-’91 steel dash.
JCampbell is offline   Reply With Quote
Old 04-04-2012, 04:00 PM   #2
rs72z
rs72z's Avatar
Re: ‘73-‘80 and ‘81-‘91 Dashboard Interchangeability
I was told all you have to change is the a/c ducts where they come out in the center and right side. Not sure if that's correct but that's what i was told when i asked the question.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 04-04-2012, 04:56 PM   #3
Jonboy
Slots go on anything!
You do not have to swap the steel dash, or even the vents, as far as I know. To swap the cluster, you probably will need to repin the dash connector, and add a wire to the connector for the oil pressure sender to the '77 harness. There will be a hole in the later dash pad for the VIN plate, too
1974 Jimmy- 5.3/4L80e/NP241
Old 04-04-2012, 05:07 PM   #4
JCampbell
I plan to swap the whole harness over from the '91, but thanks.
Old 04-04-2012, 07:04 PM   #5
J Knight
J Knight's Avatar
Your 77 has a dash mounted wiper switch and the 91 harness is set up for the column mounted wiper switch so you will need to either wire the 77 dash mounted plug to the 91 harness or use the column out of the 91. If you use the gauge bezel out of the 91 there is no hole for the dash wiper switch and the headlight switch needs to be moved up about 3/4-1in.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-04-2012, 09:15 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
i'm using the 89 sub pad in my 78 jimmy,with the 78 bezel
87 cluster in a 79 jimmy-no hookup issues,was plugNplay, not used on road tho
still looking to change over to tilt in the 78
watch out the steering box coupler changes
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
