Old 04-04-2012, 06:15 PM   #1
E.Furgal
Question 1971 Grill Paint ,What to Use?
Hello,
I have an alum grill surround that the black paint around the headlight buckets is, well tired..
What paint will have the best chance of lasting that come in a spraybomb?
Was thinking engine paint might be a good choice, if I can fine flat black..
Is it flat black.. when new?
Thanks for any help,ideas..
This is a driver,not a show car.. just want it to look good..
E.Furgal is offline   Reply With Quote
Old 04-04-2012, 06:46 PM   #2
LakeAnna
LakeAnna's Avatar
Re: 1971 Grill Paint ,What to Use?
I just did mine and I used etch primer and followed that with sem satin black (rattle can). It looks decent... and with the etch (zinc chromate) primer it will stick to the aluminum pretty well. Be sure to scuff the painted areas with 600 or scotch-brite pad so the primer can get a hold better.
The polishing was much more work than the paint!
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 04-05-2012, 06:57 PM   #3
E.Furgal
Thank u
Old 04-05-2012, 09:39 PM   #4
slikside
slikside's Avatar
subscribed
slikside is offline   Reply With Quote
Old 04-05-2012, 10:05 PM   #5
jocko
jocko's Avatar
lake anna - is the bottom section that you have painted black normally silver (paint)? Are you choosing to paint it black to match a black truck perhaps? Nice job - just curious about that lower black section - I can certainly be mistaken about what color that normally is, but thought silver.
Thanks!
Old 04-06-2012, 09:10 AM   #6
I think it looks better black and is how the factory would have done it except to save a buck. It's just a filler down there and the black paint makes it disappear while giving better accent to the surround itself. It makes the surround maintain a uniform dimension all the way around.
Old 05-22-2012, 08:53 AM   #7
E.Furgal
thanks all here is the outcome
1/4" tape then followed up with 1"
primed
and after a few lite coats of black
now to install these
