Old 04-04-2012, 06:15 PM   #1
L&L70
Exclamation Inline 6 help
On both ends of the exhaust manifold, do I have broken studs or are those locating pins? I think it is a 250 since the motor mounts are in inline with each other. Thanks guys
Matt
L&L70 is offline   Reply With Quote
Old 04-04-2012, 06:42 PM   #2
car66
car66's Avatar
Re: Inline 6 help
on the inline 6 in my truck, they look like they are locating pins
1995 Chevy 2500 4x4 diesel (daily driver)
1971 Chevy 2WD pulling truck "Whiplash"
"The Bandit" twin engine pulling tractor
"Hog Wild" 2wd econoline pulling truck
car66 is offline   Reply With Quote
Old 04-04-2012, 08:45 PM   #3
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Inline 6 help
Locating pins.They work OK on a stock truck but I would change to bolts/studs if I had the head off or was putting headers on.Just for peace of mind.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 04-04-2012, 09:41 PM   #4
L&L70
Re: Inline 6 help
Im sure the other will break this weekend, but at least Im not starting in the hole! Thanks Alot I had read that the 80's inline 6 had the one peice intake/exhaust gasket, but I think the parts store was showing the same gasket for all years. Just trying to make sure they are ordering the right part for me.
Old 04-05-2012, 07:32 AM   #5
sixtyeightchevykid
sixtyeightchevykid's Avatar
Re: Inline 6 help
the intake and exhaust gasket is one piece..
1968 chevy c10 lwb, 250 inline6, 4 speed,
sixtyeightchevykid is offline   Reply With Quote
Old 04-05-2012, 11:55 AM   #6
RichardJ
Re: Inline 6 help
'79 and later 250 had the Pulsair head with integral intake manifold and 2bbl carb.
The 292 and earlier 250 and 230 with separate intake manifold and exhaust manifold used a one-piece gasket, but there is a three piece gasket available.
Felpro's intake gasket has their Blue-Line. The two piece exhaust has a separate part number.
http://www.summitracing.com/parts/FEL-1257/
http://www.summitracing.com/parts/FEL-1448/
I tried these gaskets when I first put the headers on my 292.
THE GASKETS ARE CRAP. At least for use with headers. The exhaust lasted a week. They are crap and overpriced.
Felpro does have a one-piece, but is for stock cast exhaust.
The end studs are threaded into the head. Soak with your favorite penetrant for a day and turn out with a good vice grip with good sharp teeth. You would be doing yourself a favor if you install studs in all the manifold bolt holes.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-05-2012, 10:28 PM   #7
L&L70
Re: Inline 6 help
So the end (locating pins/studs) are threaded? If they are threaded, I would like to attempt to pull them and install studs. The rest of my manifold bolts are already studs that go over the "cradle" that catches two ears at once. I ordered a one piece MrGasket from oriellys (worth a damn?) Thanks guys for answering questions on a motor I have never had before.
Old 04-08-2012, 05:42 AM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Inline 6 help
Yes the guide pins are threaded 3/8"-16 UNC. They will back off after a good soaking with PB Blaster, or Liquid Wrench. Grab them with a good ViceGrips and twist off counter-clockwise. If you're using a stock manifold they might be OK, but if you want to run headers on your L6, then pull them off because headers will never seal properly with the stock pins on.
I use studs 3/8" -16UNC on one end and 3/8" -24 fine-thread on the other.
Old 04-08-2012, 08:49 AM   #9
L&L70
Re: Inline 6 help
Well I got the manifolds off and my exhaust has 6 cracks in it. While I attempt to locate another one, I will try and pull the pins. Is there any good ways to delet the heat riser plate inside the manifold?
Old 04-08-2012, 10:23 AM   #10
old Chevy guy
old Chevy guy's Avatar
Re: Inline 6 help
I have a 250 intake and exhaust manifold for sale in a thread on the parts board if you are interested. One of the studs is broken where the pipe bolts up but Im pretty sure I can get it out if your interested at all. The thread tittle is parting 68 250
old Chevy guy is offline   Reply With Quote
Old 04-08-2012, 01:37 PM   #11
PanelDeland
Re: Inline 6 help
I wouldn't suggest deleting the heat riser plate.It helps with cold weather running and starts.
Old 04-08-2012, 01:49 PM   #12
L&L70
Re: Inline 6 help
I am assuming that a used manifold will have a sloppy heat riser shaft. I dont like exhaust leaksand just figured I would tip the riser plate up and plug weld the steel shaft to lock it. I guess if the one I get is tight and the spring is good, I would just keep it.
