Interior Dome Light
Hi Guys, My 84 did not come with a factory headliner or dome light but I want to intstall one along with a headliner. Does the dome light mount into the headliner itself or do you have to cut into the ceiling sheetmetal to install one?
Re: Interior Dome Light
mine is in the sheet metal. I took out my headliner and just have the light up there.
You have to cut and have a lot of fun running wires
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Parts and more parts
The dome light mounts into the cab metal liner and the headliner has a hole to match that one.
Two wires, The white one is always hot (12 volt) and the orange one is your switched wire to the ground coming from the door pins.
Frank |
#5 | |
Moderator
![]() Join Date: Oct 2008
![]() White is switched ground. It goes to the headlight and door switches. Orange goes right to the fuse panel. |
