Active Member
![]() Join Date: Jul 2007
68 GMC original style winshield washer pump.
fyi: I just bought a new original style windshield washer pump for my 68 GMC and it doesn't fit the original motor mounting holes. The vendors don't mention that there are different motors and I didn't know there were either. Both are Delco motors but have different numbers on them.
The mounting holes on the new pump are farther apart than the original pump. Also, my original motor has a metal star pump actuator (not sure what it's called) that's taller and the 69 Chevy has a nylon star one. Be sure and measure yours if you ever have to replace it. These are approximatel measurements. 68 GMC washer pump holes are app. 3 and 7/8 inches apart and the new one (similar to the one on my 69 Chevy) app. 4 and 7/8 inches apart. |
![]() Join Date: Aug 2005
Re: 68 GMC original style winshield washer pump.
I ran into that problem on my '67. Seems '67 and early '68 use a different wiper motor than '69-up. I got lucky and found an NOS washer pump repair kit (part #4914074) but good luck finding another one. Your best bet might be to replace the wiper motor with the '69-up style and use the newer pump. As far as I know the wiper motors interchange.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
#3 | |
Active Member
I actually bought a kit first (cap and rubber valves) but this Texas heat had made the plastic brittle on the old pump and basically just fell apart. I'm going to keep the old motor as a spare and probably mount a new style washer motor in it if I need to. |
Chemist under the hood...
What a coincidence! I was doing the same thing today on my '67 and had the same problem with the part I got from Rock Auto. The new one is too long. I still have a remote pump but I wanted to change back to stock.
Do you have pics of how the washer hoses are routed in case I get another pump that will fit? Thanks
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Active Member
I'll take some tomorrow.
Thanks-I read quite a few posts last night and most advised against using the stock pumps as they are apparently not reliable and can leak etc. What do you think?
#7 | |
Active Member
One other thing, I'm not going to use carpeting on the floor board so if it leaks it won't be too much of a problem for me. What pics were you wanting regarding the routing of the hoses? |
Active Member
If you decide to go the new style here's a post that SFTorange put up some time back. If I were to decide to put a new style on the motor this is what I'm going to do.
http://67-72chevytrucks.com/vboard/s...d.php?t=489265 |
#9 | |
#10 | |
#11 | |
Active Member
This is the way I have mine. |
Active Member
Also check with Wes. He's got all the three hole grommet and other rubber grommets you may need.
http://www.classicheartbeat.com/rubb...atherstrip.htm |
#13 | |
Thanks for posting the pictures.
| Bookmarks |
