04-04-2012, 09:44 PM | #1 |
Engine compartment light issue
Ive installed a new bulb. I can't get the light to work. Is there a switch somewhere? The manual doesn't even mention a engine compartment light and nothing shown in the fuse panel.
It's a 1999 c1500 2wd suburban. Thanks guys. Posted via Mobile Device |
04-05-2012, 01:42 PM | #2 |
Re: Engine compartment light issue
Look at these pictures below. I don't see a switch or mercury or whatever controls it.
Thanks guys. |
04-05-2012, 05:19 PM | #3 |
switch is bulit into the back of the light i believe have you check the ground and the wire inside wire loom
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-05-2012, 08:28 PM | #4 |
yes sir. Ground and wire in loom intact correctly. No switch on back on light. Man I wish though.
04-05-2012, 09:14 PM | #5 |
after some research the mercy switch is in the light somehwere http://www.dieselplace.com/forum/sho...d.php?t=231675
04-05-2012, 09:17 PM | #6 |
You should have 12 volt on the orange wire to the lamp house. there is a inline merucry switch that compleats the power to the bulb when the hood is in the open position. The lamp house power wire may have a poor connection where the factory has it solder to the merury switch. When the work they work good when they dont i find it best to drill the rivets and head to the work bench.
Trueman |
