Old 04-04-2012, 09:45 PM   #1
lotik
drag it like you stole it
Inner Fenders on a Budget
About 4 Hours and 2 $30 trailer fenders later...
I didn't realize how much clearance the tires would need, but the inner fenders had to be placed almost even with the tops of the fenders, allowing about a 1/4" gap when the truck is laid out. Some massaging the bottom side of the hood will need to be done, but shouldn't be too big of a deal.
Next up is a set up Porterbuilt hood hinges, and all the welding and cutting should finally be complete.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 04-04-2012, 10:21 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Inner Fenders on a Budget
Looking good!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-04-2012, 10:52 PM   #3
trkfrk
trkfrk's Avatar
Wow!!! I like it.. Simple and clean....
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 04-05-2012, 02:06 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
Looks good! Did you get them locally or online? If online, mind shooting out a link?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 04-05-2012, 02:15 PM   #5
JRANGER
JRANGER's Avatar
So I take it your gonna modify the hood to fit since they look in the way of it laying flat?
JRANGER is offline   Reply With Quote
Old 04-05-2012, 02:29 PM   #6
lotik
I picked the fenders up locally. Any trailer supply should have them in stock. These are 9" wide.
Old 04-05-2012, 02:31 PM   #7
lotik
Yes. I looked at the hood and it looks like I can just cut the pinch weld section that extends below the top of the fender. I only have to cut the distance that the inner fender is exposed. I can the weld the hood back up. Shouldn't be too difficult. I'll post some more pics after I get that done.
