04-05-2012, 01:40 AM | #1 |
Please, help me with removing pass. exhaust manifold
Can someone please tell me what I am doing wrong, pass side exhaust manifold is cracked. I've undone the bolts from the block, but the top has this square like bolts that will not budge with adjust wrench, also cannot get bolts loose that connect to the exhaust pipes using long 9/16 socket.
Is there a way to get this done without an impact gun? Thanks so much for advice. Also, pass exhaust pipe is twisted under bed of truck now, I know because muffler is crooked. 85 swb 305 v8 Dual exhaust Posted via Mobile Device |
04-05-2012, 07:38 AM | #2 |
78K & 79C Jimmys
Re: Please, help me with removing pass. exhaust manifold
i"ll be doin this later,got my mufflers in
if rusted solid and not being reused,snap off the 9/16 up to the manifolds I will hit the manifold bolt straight on before turning,trying to shock/loosen it a bit when you put new nuts on the exhaust consider brass nuts! they don't rust
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-05-2012, 01:30 PM | #3 |
Try using PB blaster, make sure it doesn't get into the engine or anything bad like that, or use WD40. then put the wrench on it, and hit it with a rubber mallet
1976 GMC SIERRA CLASSIC CAMPER SPECIAL! 454 BIG BLOCK BABY! |
04-06-2012, 01:15 AM | #4 |
What am I missing here, I tried still nothing. Square bolts that goes into head, not engine block. Anymore advice is appreciated. Thanks.
04-06-2012, 01:24 AM | #5 |
Torch? wait for someone else to chime in before you try that though! don't wanna mess anything up
04-06-2012, 06:01 AM | #6 |
Those square like bolts might be pipe plugs used when the air injector tubes are removed.
Might just cut exhaust since its twisted, easier than getting some really stuck bolts that hold the pipe on. |
04-06-2012, 08:59 AM | #7 |
78K & 79C Jimmys
it's not the "other" temp sending spot? coolant?
does the manifold look like this?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 04-06-2012 at 09:21 AM. |
04-06-2012, 09:31 AM | #8 |
78K & 79C Jimmys
or
04-06-2012, 03:01 PM | #9 |
That is the location on the square bolt, unlike the pic it has no connections to it. And it is 2 bolts, 1 is thru the first hole on engine, the other is at the back of engine by motor oil dipstick.
My dumb (smartphone) will not let me upload pics to photobucket, or vids to youtube. I will keep trying. Thanks. Posted via Mobile Device |
04-06-2012, 06:33 PM | #10 | |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
04-07-2012, 08:26 AM | #11 |
78K & 79C Jimmys
x2
04-07-2012, 12:53 PM | #12 |
Its the same location at the top of exhaust manifold, but is not the same thing. The bolt on mine goes from that location into the exhaust manifold hole on engine block. Not to be confused with the six bolts on the exhaust manifold.
These square bolts are the only thing holding the exhaust manifold up, as the six bolts have been removed without trouble. I am thinking this is why it stayed cracked so long, its a pain in the ass to deal with. May end up putting it back. Thanks. Posted via Mobile Device |
04-07-2012, 12:55 PM | #13 |
These square bolts are the only thing holding the exhaust manifold up, as the six bolts have been removed without trouble. I am thinking this is why it stayed cracked so long, its a pain in the ass to deal with. May end up putting it back. Thanks. Posted via Mobile Device Posted via Mobile Device |
04-07-2012, 12:57 PM | #14 |
Sorry for the double post. Even tried vise pilers, smaller socket.
04-07-2012, 01:07 PM | #15 |
78K & 79C Jimmys
Suggest posting a picture
04-07-2012, 02:05 PM | #16 |
Can't because my phone will not upload.
04-09-2012, 07:00 AM | #17 |
here it is
04-09-2012, 07:20 AM | #18 |
That looks like an old plugged air-injection tube. With the flange bolts loose from the exhaust that should just come out. I don't think that is a bolt or has any function at all. You could just cut it off but you risk it falling into the cylinder. If you do cut it off turn the engine over til the exhaust valve is closed. If you take the motor mount bolts loose and lift the engine you may get enough room to pull it straight out. Since your manifold is of no use to you don't worry about hurting it.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
04-09-2012, 10:40 AM | #19 |
78K & 79C Jimmys
wedge it from moving...vise grips
couple of nicks/cuts into both sides, with a grinder/ cutting wheel, hammer it , bet it would crack off heck hitting it with a small sledge alone, might crack that
04-09-2012, 01:05 PM | #20 |
03-29-2013, 01:12 PM | #21 |
Sorry for the thread revival, but I am in a pickle.
I have a 72 C-10, 350/350, and one of the nuts on the driver side exhaust mani (manifold to exhaust flange) backed out and fell off. The stud is good. I need dimensions of the nut size. The hex is 9/16", but what thread type? Posted via Mobile Device |
03-29-2013, 02:12 PM | #22 |
If its all original everything on the exhaust is 3/8-16 threads
