Old 04-05-2012, 08:51 AM   #1
MalibuKasey
Artist
MalibuKasey's Avatar
How low before a 2 piece driveshaft is advised
So.... Looking at all the LOWWWW trucks Ive noticed the one thing most (not all) have in common is the use of a 2 piece driveshaft. Assuming this corrects alot of binding/pinion angle problems. So at how low is it recommended to change? Im currently at 5.5/7 but getting ready to go to 6.5/8. Ive noticed most of Delmos trucks have the 2 piece as well.
So hopefully you guys can shed a little light on this for us. Any things to take in to consideration when switching to one or things to look for or even the right way to measure for one etc. Your knowledge is much appreciated.
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 04-05-2012, 11:02 AM   #2
Vics63Chevy
Vics63Chevy's Avatar
Re: How low before a 2 piece driveshaft is advised
Good question, im also interested in finding out as I'm close to getting a driveshaft and I'd like to get the right one the first time around..
1963 Destiny Build Log
Vics63Chevy is offline   Reply With Quote
Old 04-05-2012, 05:23 PM   #3
Notch1988
Notch1988's Avatar
The reason is because eventually the driveshaft will hit the cab floor. So your options are to tunnel the cab floor or run a two piece.
66 GMC swb dropmember accuair
Link to my build:
My GMC Project
Notch1988 is offline   Reply With Quote
Old 04-05-2012, 06:13 PM   #4
daverod
SSN 706
daverod's Avatar
My 66 lays frame with a one piece. Did'nt do anything to the cab. Wheel/tire combo is 30" tall.
daverod is offline   Reply With Quote
Old 04-05-2012, 06:22 PM   #5
Malibob
Malibob's Avatar
Kasey, mine only has one pc. shaft. My floor hump was grafted in from a donor vehicle though. I have heard that high hump trucks can lay rockers without modification to the hump- but not seen one.
and mine is this low:
My '64 C-10 by Malibob, on Flickr
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
Old 04-05-2012, 08:11 PM   #6
daverod
SSN 706
daverod's Avatar
What was I thinking mines a 2 piece. Thats what I get for having to many projects.
