Has anyone put a Cold Air Induction on their truck?? I know this is Hot with the Jap Cars, but I haven't heard much with Trucks like ours.
Just Wondering!!
Rob the ToonMan 56 Chevy Cameo----Custom, [Turquoise] 67 Chevy C10 Short Fleetside (Black & White) 63 Trailorboat-------Teardrop Style Trailer 69 Honda CM90 |
I'm back with 2nd truck!
Maybe like Swervin's ram air box?
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Rollin' Member
i had it on my old honda - it made a difference, but i know with that one it helped to have it breathing on the backend too. but i am interested in this too. swervins set up is bad ass
:: 1977 C10 cheyenne :: :: 1973 new yorker brougham :: for sale - $1,500 lofat productions |
I was unaware of Swervin's set up!?! Sounds Interesting!!!!
Any Pics of His out there?? ToonMan
Rollin' Member
COOL!!! Thanks!!!!!
"The dude abides"
Cold air induction is always a benefit and usually a cheap and easy way to gain a bit more power and some better fuel economy. On the trucks cold air induction is actually pretty easy to do since there is more then enough room to do it.
I am going to do this to my Cutlass in the future and I am going to do it to my truck as well. Since it originally did have a cold air induction because it was a diesel. But the moron who put the 350 on it, put a choked down air cleaner snout on it and never ran the tube up to the core support where the bracket and everything are still at.
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
http://home.houston.rr.com/chevy73/ramair.html
There's some pics of mine. Same as Swervin's. -- Mike
http://home.houston.rr.com/chevy73/ |
BeWarE tHe eViL CrAnkTOe!
yep...it works...pretty cool setup too....just too bulky for me.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods ![]() www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
#10 | |
-- Mike
I just cut the block off plate on the stock air intake at the radiator support. Im sure the air flows better this way (when moving). I have not had any problems so far. After the first few hard rain storms I checked to see how high the water would get (without the block off plate), it didnt even get half way up the snorkle.
It may not be as good as two, but its better then stock. Here is the only picture I have of it:
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
Did the same on my 83
#13 |
PHOENIX, where did you pick up your Billet Grill???
#14 | |
My opinion is that the force of the truck moving forward cause a ram air effect around the baffle without a need for removing the baffle. -- Mike
#15 |
Thanks guys for all the answers and tips!! Great Answers!!
I really appreciate it!! Looking Good TX Mudder!! You Too Phoenix!~!
#16 |
I bought my grille from www.aztrucks.com. It was $116.00, it is the polished grille. I bought it from them because they are local and not far from my house. I was able to save the shipping cost and get it right away (best of both worlds
![]() TX_Mudder: I don't take my truck off roading. It does go off road, but not crazy like if it was 4x4. I have drove it at different speeds all around town in the rain and throw puddles to test it out. Water wont travel far up the tubes. Like I said it only goes about half way up and that was just little droplets. I like the ram air box. I would get one, but there are too many other things I need. Toonman, run a search here and on ebay. People modify them to make the stock a dual snorkle. I remember swervin did it, but he wasnt happy with the outcome. A guy on ebay had one that looked like it was done pretty well. If I remember correctly he welded on the second one from the inside and it looked pretty clean.
#17 |
Has anyone seen this done on the 67-72 trucks?
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#18 |
Yeah baby!
Blue Beard,
I have it on my '68, I cut holes in the rad support and ran the ducting thru to the upper grille. Might be able to e-mail pics but the above description pretty much says it all.
11.37 @116 |
#19 |
68racer....
PM'd you on your idea.... Thanks,
#20 |
PHOENIX
Thanks for the Idea!! Right now I have taken a stock Air Cleaner and Hooked up a 4 inch hose to it and attached it to the Stock truck inlet in the core support. I then took the Baffle and hit it with a 2 1/2 Hole saw, so the Air has a straight shot down the hose, but still retains some protection from the Baffle!! Seems to be working great!! The Idea of adding a second inlet to the stocker has crossed my mind. As you said, if you welded it from the inside, it could look pretty good!! I may try that eventually!! Thanks!!
#21 |
Ram Air
http://www.ramairbox.com
but, if you buy the GM intake snorkel, buy it from http://www.gmpartsdirect.com 12.95 from Ram Air -vs- 3.65 Gmpartsdirect - each Last edited by Nvbowtie; 05-23-2003 at 04:05 AM. |
#22 |
as an alternative, you can try to find the old dual air induction from old Bel Air's and also Corvette's. They both have had dual cold air options since the 50's. Not very common though.
The "Japs" actually got the idea from us. ![]() ![]() |
#23 |
Well now I got it hooked up and working on my truck, a friend wanted to do the same to his N#ssan. So we did it and he can't believe the difference!!!
Thanks for all of the help guys!!!
#24 |
BAD BOW-Silverado XST
Waiting to see when someone will run their A/C into the intake.
#25 |
Now there is an Idea!!!!!
![]() ![]() Really cold air induction!!!!
