Old 04-05-2012, 03:43 PM   #1
86chevybob
Exclamation New to forum, have a starting issue cant figure out
Hello hope someone can help me out, I'm having a problem getting my truck to start unless i move the shift lever and steering column around, and when i do get it started (not always) the left backup light is on and i have to pull up on shifter lever to keep starter from still running.This all started when my lock cylinder would not go into acc, so i took steering column apart (way more than i needed to) to clean lock cylinder and see if i could get it to go into acc which i did. Then the fun started when i had to put it all together, had a hard time getting the actuator rod and sector cam lined up just right. After getting it back together tried to start truck with no luck,did this numerous times with no luck. So now i bought a new lock cylinder and took ignition switch off column so i could get actuator rod and sector lined up, boy was that easy doing it that way. Then i put everything back together on column and put ignition back on column and actuator(cylinder in locked position along with ignition swicth) Everything seemed ok but still no start, i have the column support bolts loose so i can move column up and down a little along with pulling on shift lever til truck starts then have to move shift lever around to get starter to stop being engaged. Hope i explained this so someone can help me out. Thanks
86chevybob is offline   Reply With Quote
Old 04-05-2012, 04:34 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: New to forum, have a starting issue cant figure out
sounds like you may need to adjust the lowe ignition switch it has a little play in it for this
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-05-2012, 05:15 PM   #3
86chevybob
Thanks Old Rusty for the info i will try to adjust that switch. i also been reading about my neutral safety switch and that is adjustable also. I will let people know what i find out.
ignition switch, lock cylinder, starting problems, steering column
