Bit the bullet/Let me know what you think?
Here is what I ordered today:
LY6 2010 80k 6L80E 2009 2miles Included: ECM TCM Fuse box Exhaust manifolds Accessories: starter, alt, ps pump, bracket Wiring harnesses Mass air TOTAL : $2964.00 Aso putting a Mast VVT cam & springs in this Any heads up on this swap would be aprisheated. Going in 72 chevy truck Posted via Mobile Device
~72 Chevy Truck~ Motor: LY6 6.0 Liter Trans: 6L80E Still under construction |
Re: Bit the bullet/Let me know what you think?
Did you get the pedal assembly and wiring for it?
That should be a DBW set up! By the way sounds like a good deal,you should get a lot of miles out of it. Last edited by Indian113; 04-05-2012 at 06:56 PM. Reason: Fat Fingers |
No pedal. They did not have one. =( got it all from LKQ. I'm very happy with my experience. This guy was very helpful Justin 469-941-3743 tell him Adam sent you
~72 Chevy Truck~ Motor: LY6 6.0 Liter Trans: 6L80E Still under construction Last edited by Nitschke; 04-05-2012 at 07:17 PM. |
shame it will probably cost you a couple hundred for the pedal...but keep posted witth your build
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
#5 | |
The TCM is inside the transmission, So if they are sending a "external" TCM its no good to you. Any more details on the ECM and what its out of? |
#6 | |
The TCM will need a reflash, Its VIN specific. You can either......build the truck & take the whole thing to a tuner/Have the tuner come to you, Or remove the TCM & Valve body & send it off along with the ECM to get tuned/reflashed.
Or convert to a throttle cable style and rewire as needed.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
Would I need any DBW from the same year as the motor like any gm car or truck of the same year or more specific? Thanks for the info, specific as posibal is ok.
Also anyone have any good wiring diagrams that would like to share ![]() Posted via Mobile Device
Nitschke,I have a DBW pedal and harness for the pedal from a 2004. If it would work for you it's yours if you pay the freight. Ray
#11 | |
#13 |
I have a DBW ECM and the guy that is working on my wiring told me he could set it up for a Cable drive as I can't use the DBW with a 700r4
#14 | |
![]() Just trying to help out I might need something sometime myself!! ![]() |
#15 |
Your running a Gen III 24X engine, Nitschke has a Gen IV 58X engine & running a 6 speed auto this really limits him on what he can do. The DBW pedal off a 04 itself may work, But I would just get the correct part.
#16 |
Thanks, This is all new territory for me. I was hoping I could help out.
#17 |
Got the motor trans in here are some pics. I checked the numbers it is what its sopost to be! I pulled the valve cover off it looks excellent!
![]() Let me know what you think? Im going to start a build thread I think. Anyone know a good way to clean the ox off the the heads? I dont want to paint them and im going to beed blast all the things i can to clean them. ![]() ![]() ![]() ![]() O and what is this? It came 20min after the motor via UPS. and do i need it? ![]() ![]()
#18 | |
Where is the ECM? Did it come with a separate harness? The one on the engine is cut up. The transmission is out of a 4WD/AWD truck/SUV, Is that what you wanted? |
#19 | |
