OBS guy
Any of you Blazer owners ready to swap keys?
I am looking for a 69-72 K5 OF EQUAL VALUE in exchange for my 96 K3500. I have a pretty amazing truck. This isn't some bolt together erector set truck, this one is built right. I am not ever sure if a truck can be built any better frankly. It's reliable, perfect road manners and 0 issues. I won't be motivated at all to sell under 12k. This isn't the run of the mill truck here. This thing is built to look awesome, it has AMAZING road manners, and it has power to spare.
I happen to have a soft spot for 69-72 Chevy trucks, blazers and suburbans and I want to see what is out there. Your truck has to be DONE for me to consider it. DONE means no outstanding work needed to drive. No electrical problems, trans problems, steering problems, etc. Anyways, this is my truck that I built: a 96 k3500 crew cab long bed, smogged and tagged and ready to go. It gets 12-13MPG which is pretty dang good for a gasser. ![]() Vortec 454 w 115k original miles Whipple Supercharger @ 6lb boost Runs on 91 Octane Volant Cold Air Intake Extreme FI throttle body 42# flow matched fuel injectors (Wester's Garage) Wester's Garage custom tuned ECM (no Whipple piggyback fuel module garbage) Exhaust gas temp gauge Boost gauge Flex-a-lite dual e-fan conversion Edelbrock TES headers Full Performance Distributors (HEI) ignition upgrade- wires, cap, rotor, module, coil Hypertech 180 degree thermostat High flow cats Magnaflow dual in/single out to 5" tip behind passenger rear tire Dual Innovate Motorsports WB02 sensors (1 each bank) Full datalogging capability- Innovate Motorsports OT1 + Innovate Motorsports LMA3 On top of datalogging all OBD2 data, system logs AFR from WB02, EGT, Boost, etc. All smog equipment in tact. Truck passes smog fine. Lifetime tunes available from Wester's Garage. Oil cooler. 4L80E transmission Built up 15k miles ago @ shop in Phoenix AZ. Trans rebuilt before I bought 2.5 years ago. Runs and tows perfectly. Fluid is clean, no codes, no jerkiness. Trans temps never go above 200-210 even when pulling a grade in summer with a trailer. B&M huge aluminum trans pan Huge transmission cooler Autometer trans temp gauge (mounted in triple gauge pillar) Differentials 5.13 differential gears front/rear professionally installed at ORW in Temecula Rebuilt/balanced rear driveshaft Rear high capacity differential cover Suspension/steering Cognito motorsports double shear braces with brand new idler/pitman arms Brand new steering box Tie rod ends & balljoints in good shape Full Energy Suspension poly suspension up front New rancho steering stabilizer Torsion bars aren't 'cranked' for lift 6" Procomp suspension lift Procomp rear traction bars Bilstein 5100s all around Dual shock hoops with powdercoated Procomp shocks Appearance Cowl induction hood RBP grille Updated headlights (not cheap eBay crap, these are TYC Elegante) Diesel smoothie bumper N-Fab step bars Tinted windows Bed & tailgate caps New taillights 37x13.50R20 Toyo Open Country MTs on 20x10 KMC XD Diesels with beadlock rings. 80%+ tread. Front skidplate Spray in bedliner Rear 2" wheel spacers made in STEEL specifically for this truck by Fred Goeske in Los Angeles Interior Triple gauge pillar - trans temp, EGT, boost Autometer gauges Towing brake controller, fully wired to flat 4-pin and large 5 pin connectors two gauge pod in overhead console - AFR from WB02 Innovate motorsports gauges Asus Aspire Netbook for datalogging from Innovate Motorsports modules (virtual gauges too) Alpine head unit w/ipod integration 2 Precision power amps Front Kenwood components in front doors, 2 way Kenwood 5.25" speakers in rear doors, 2 10" JBL subs behind rear seat Tons of bass, no blown speakers Seats in SUPER shape Carpet in fair shape Tinted windows Thing is fully up to date on service, everything works. 4wd works perfectly. The truck has AMAZING road manners for towing. AC blows cold. No trouble codes, no hidden surprises.
88 Suburban Goodies- Alpine, Auto Meter, BDS, Bilstein, B&M, BFG, Borgeson, Bushwhacker, Cowl hood, Flowmaster, Genuine Gear, Holley, Infinity, JVC, K&N, MB Wheels, MSD, Pioneer, Skyjacker, Sony, Thorley, Walker + more |
OBS guy
Re: Any of you Blazer owners ready to swap keys?
Here's the motor
Neat truck. I'm actually looking for a suburban but I'm not willing to give up my 72 for it. Good luck with the sale.
SKINNY TIRES RULE!
Good lookin' truck.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
OBS guy
This is my old k5. Some of you may remember it.
Blazer looked great. What was the lift, wheel/tire spec on it?
ima guess 8 inches and 38s
Chris Heinz |
OBS guy
It was 6" suspension + 3" body + 38s.
