Old 04-05-2012, 06:09 PM   #1
Breadstick
What shocks are these?
When I bought my truck, it had these shocks in the back. Each one has an air line ran to a "t" that goes back to the back cross sill where it ends in a tire valve of sorts. I'm assuming the height is adjustable by putting air in or taking it out the valve in the back. Is this right? I've never had an adjustable suspension before, so I'm not sure.
Breadstick is offline   Reply With Quote
Old 04-05-2012, 07:36 PM   #2
cdowns
cdowns's Avatar
Re: What shocks are these?
a very common accessory for trucks and station wagons// air shocks help to somewhat lift a sagging rearend
available from GM back in the day and numerous aftermarket suppliers
still available in autoparts stores
Old 04-06-2012, 01:38 AM   #3
jhngardner367
jhngardner367's Avatar
They also help when towing. I put them on ALL my trucks.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 04-06-2012, 06:11 AM   #4
andrewmp6
Yeah they are air shocks they work good if you tow,But most used them to cheaply lift a saggy rear suspension on cars and trucks.
andrewmp6 is offline   Reply With Quote
Old 04-06-2012, 11:10 AM   #5
Breadstick
Thanks for all the replies. I don't usually haul things in my truck and if I do, it's usually not much. If I let some air out, it should drop the back suspension a little, right? It's a little higher than the front.
Old 04-06-2012, 11:57 AM   #6
cdowns
cdowns's Avatar
trucks never set level from the factory// those air shocks should always b aired up at least 10-15lbs minimum for them to work properly and to not wear out the seals
Old 04-06-2012, 12:45 PM   #7
Breadstick
Thanks for the tip. I'll make sure to check them later today.
