Old 05-07-2003, 03:51 AM   #1
72gmcshorty
72gmcshorty's Avatar
Wiring questions......
Does someone have a picture of the where the grounding strap goes for frame to inner fender? Will this make my headlights stop acting all goofy?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-07-2003, 10:29 AM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If two post show up sorry the first got lost I guess for a while.
I dont have factory spects on this but,Ive seen grounds run from intake to fire wall, motor mount bolts to inner fender skirt,battery to core support, You want battery to engine block,block to frame,frame to body, its not important where you hook it up as long as you have it ,It will cure a world of electrical ailments
sneakysnake is offline   Reply With Quote
Old 05-07-2003, 12:36 PM   #3
SEVEND2
SEVEND2's Avatar
check and make sure your grounds on your voltage regulator (located near where stock horn goes) are tight, I just found my lights being inter-mittant on and off
My grounds are at voltage regulator, inside of the outer fender well between batt and hood hinge , and the Main neg, on Block near fuel pump
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 05-07-2003, 12:40 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Check your hi-beam switch on the floor and your ground wire on the top of core support on the passenger side.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
