04-06-2012, 04:07 AM | #1 |
front sway bar question..
guys , ive just got myself an ol' 70 stepside to restore,, and wondered did these trucks come with a front sway bar? this one hasnt got one but im thinkin' it needs one? there are no brackets or remnants of any sort under there?
thanx, Gav |
04-06-2012, 06:16 AM | #2 |
Re: front sway bar question..
It was optional on these trucks. You can usually find one on the parts board.
72 Cheyenne Super 80 Silverado Blazer 2wd |
04-06-2012, 09:55 AM | #3 |
Florida Edition
Probably the cheapest way to improve the handling of these trucks.....
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
04-06-2012, 10:29 AM | #4 |
Registered Cruiser
Look for a 1 1/4" bar. Many other year models will interchange. Mines from a '79 C-30. The neoprene bushings last much longer than rubber, but can squeak a little. If you plan on lowering the truck, it's a good idea to relocate the front mounts. Happy hunting.
I just noticed you're from oz. That might make it a little harder to find one in a wrecking yard, but I'd do my best if I were you. Shipping one could be rather pricey. G/L
I intend to live forever. So far, so good. Last edited by jhwkns; 04-06-2012 at 10:34 AM. Reason: editing |
04-06-2012, 11:39 AM | #5 |
I found one last year for $40, and discovered after removing all the decades of dried mud and congealed grease on the front end, all I had to do was bolt it into the existing holes.
Really handles much, much better now. I'm amazed at how much corner sway was eliminated. |
04-06-2012, 12:31 PM | #6 |
Sisyphus was my mentor!
http://www.67-72chevytrucks.com/vboa...highlight=sway
Got my 1 1/4" bar from a 73 - 87 Chev or GMC tow truck. Those should be more plentiful than 67 - 72's down there...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
04-06-2012, 02:48 PM | #7 |
My 1 1/4" bar was from a 79 C-20 from pick and pull for $25. Early classic enterprises has the frame mounts for stock height and lower trucks, they also have bushing and strap kits. I'll probably be in it for about $60
04-06-2012, 05:02 PM | #8 |
thanx guys ,, there are some around but not in the wrecking yards here.. most guys restore them or stockpile there parts. Ill prob get new from one of the major suppliers and deal with shipping as we do here with everything from the US. at least the aussie dollar is strong right now which helps ..
