Old 04-06-2012, 10:53 AM   #1
dwatts1984
Help Me Please ... Window glass and power regulater install...
So what had happened was...
I brought my truck to get it painted by"some guys" they took everything apart... &%$#@^ up ( ) the paint jobs and didn't put anything back together... needless to say i now have to put the window glass and regulators and everything else back together all after never seeing what it looked like from the start...
Does any one have any images of what this is supposed to look like? Step by step info? Im so screwed right now...
HELP
86 gmc 1500 LWB
dwatts1984 is offline   Reply With Quote
Old 04-06-2012, 11:09 AM   #2
bilfman
bilfman's Avatar
Re: Help Me Please ... Window glass and power regulater install...
I just did my doors and it wasnt too much of a pain, I actually found putting it back easier then pulling it apart. I don't have any pics. The only thing I can really suggest to you is to find an old scrap door to use as a guide, plus that would give you some extra parts to work with as well. Other then that when i reinstalled it all I started with the wing window first.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-06-2012, 01:06 PM   #3
ramz
ramz's Avatar
Give me a couple days... I'm doing my driver door this weekend...
ramz is offline   Reply With Quote
Old 04-06-2012, 05:49 PM   #4
Square_78
Square_78's Avatar
Why didnt they put it back together? Why did they pull the window regulator out from iniside the door to paint it?
Square_78 is offline   Reply With Quote
Old 04-07-2012, 03:22 PM   #5
ramz
ramz's Avatar
Just got done with mine.
There are 4 bolts that hold the regulator/motor on the door.
You will have to open the regulator and squeeze thru hole where the door handle cable is. Once its in put the regulator on the window rails then bolt the 4 bolts
Old 04-07-2012, 05:24 PM   #6
nekkidhillbilly
well i to paint one right you have to take the glass and vent window out
nekkidhillbilly is offline   Reply With Quote
Old 04-07-2012, 09:35 PM   #7
1425956
1425956's Avatar
No reason to remove the regulator or the window to paint it the right way. Just roll them down and tape everything up. However, I do see a need to remove the window rubber trim and window seals. Just replaced both regs and motors on my 84 and it was a breeze. An hour to do both. Like the PP stated, 4 bolts (2 nuts, 2 bolts) and it is done.
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
